CTS wont stay running, BAD ECM
Results 1 to 6 of 6
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, CTS wont stay running, BAD ECM in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hello, I have a 2004 cts and i believe the ecm to be bad. The key is stuck in the ...
    Paul Reed's Avatar
    Paul Reed is offline Cadillac Owners Member
    Automobile(s): 2004 CTS, 2006 DTS III
    Oct 2010
    Houston, Texas, United States,
    28
    56
    Hello, I have a 2004 cts and i believe the ecm to be bad. The key is stuck in the ignition and when the key is turned, it doesnt turn over. I have tried removing the harness in the fuse box or removing battery power to no avail. Also tried new battery.
    Im getting this weird long beep noise in the engine compartment as well.
    I found a older thread where a fellow also had a 2004 cts in which he jumped the starter wire and started it that way, but when i do that, it cranks for a second, and doesnt stay running. Sounds like a bad fuse, but i dont know where to start.
    You can see the symptoms and long beep in the video below.
    Paul Reed's Avatar
    Oct 2010
    28
    56
    Re: CTS wont stay running, BAD ECM
    Also, I tried the procedure to manually release the key, but I can't seem to do what the instructions say..
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    394
    There is a small hole dead center under the steering column. It has a plastic cover you need to remove. Use a straightened paper clip or other pointy object to depress the key release mechanism while turning the key to off at the same time.
    As for the not starting issue, is the check engine light on with the key in the on position? Traction light on? Gas gauge at zero?
    Paul Reed's Avatar
    Oct 2010
    28
    56
    Got the key out. Need the part number for the ecu
    Nov 2008
    SW Ohio
    36
    394
    I believe the part number is 12592124 but double check with your local GM dealer.
    cmjohnson is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS luxury package
    Nov 2003
    300
    Plenty of CTS ECUs are on ebay, starting at 40 bucks. For that price it's worth the gamble that (a) it works and (b) it can be reprogrammed for your car.
  9. Remove Advertisements
