2003 CTS Moonroof Leaking
Results 1 to 4 of 4
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2003 CTS Moonroof Leaking in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Ok! I have done 1. adjusted sunroof so it's leval with roof line. 2. i have pushed Weedline down drains ...
    woodscaddy's Avatar
    woodscaddy is offline Cadillac Owners Member
    Automobile(s): 2003 CTS
    Jul 2012
    Phx, AZ
    43
    3
    Ok!
    I have done
    2. i have pushed Weedline down drains holes... (but it stops.. feels light couple feet down..) Followed drain hose took A piler cover off to under carpet driverside then to a rubber drain out into frame then how long from there ummmmm.. where does it end. where can i see end of hose.
    3 blew air thru lines as well...
    Diverside hole still wont drain.......
    I live in AZ and I baught car 6 months ago... And for some reason we have had a lot of rainy days and my headliner is soked and water spots..
    Please HELP!!!!!
    Bill Martin is offline Cadillac Owners Member
    Automobile(s): 2003 CTS, 2011 Sts
    Jul 2012
    20
    Re: 2003 CTS Moonroof Leaking
    I don't have any good news for you. Mine would fill the drivers floor with water, took it in to be fixed at $130.00. Next big rain it leaked again took it back and they added an extension line for $12.00, no problems since. Apparently it was pulling apart at a joint. This was done by the body shop as it involved removing panels.
    CadillacAsAlways's Avatar
    CadillacAsAlways is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS 3.2L, Luxury Sport, Diamond White
    Aug 2012
    Pittsburgh, PA
    659
    Quote Originally Posted by Bill Martin
    Your driver floor was wet? Elaborate a bit...yesterday i noticed that my my driver floor is damp underneath my mat and I'm awfully confused cause I have no idea how it would get wet...
    woodscaddy's Avatar
    Jul 2012
    Phx, AZ
    43
    3
    Ok I fixed it I hope!!!!
    The drain is inside door seal.. Open Door look by Hinges to door and will see black Circle and the hose is attched to that... I had to push Weedtrim Line from the bottom of drain hose.. It had a tone of crap that came out and stank... I pulled Weedline back and forth like flossing your teeth and drains great pourd a bottle water in tray and drained great.. Keep Fingers Crossed...
  7. Remove Advertisements
