Solenoid location? p0443
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Like Tree3Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Solenoid location? p0443 in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I am getting a p0443 code on a 04 3.6l. Based on some research ,the solenoid may be bad or ...
    Cads4life's Avatar
    Cads4life is offline Cadillac Owners Fanatic
    Automobile(s): 12 CTS Premium - 10 CTS Luxury - Sold= 04 CTS Luxury
    Jul 2010
    Schaumburg, illinois
    23
    311
    ExclamationSolenoid location? p0443
    I am getting a p0443 code on a 04 3.6l. Based on some research ,the solenoid may be bad or bad connection.where is the solenoid located and has anyone else have had this issue with a solution?
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,149
    Re: Solenoid location? p0443
    It is in this picture. If you follow that tube from the T/B area as it bends around the upper intake. You can see it attached to a device with a white plug, or another hose, to it. That is the solenoid that you are talking about. It's only two tube connections and one electrical connection.
    It'll take you longer to remove the plastic engine cover than it is to replace that device. lol Mine was replaced under the special extended warranty that GM ONLY offered on the 2006 model year. Why they offered it on that model year only is beyond me.
    KOT
    Cads4life's Avatar
    Jul 2010
    23
    311
    Thanks KOT for the helpful info. Is there anyway to check if this item is defective and if this is the part that is causing problems?
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    The parts pretty cheap, as well just replacing it if its been on since factory http://www.rockauto.com/catalog/x,ca...,parttype,4936
    Jhayzhone's Avatar
    Jhayzhone is offline Cadillac Owners Member
    Automobile(s): Custom 2007 cts
    Jan 2012
    Canada
    74
    I have a question regarding to that purge solenoid. Is it normal that you will hear a thicking noise in that solenoid once you turn you engine on?
    Apr 2009
    Ledyard, CT
    37
    9,149
    Quote Originally Posted by Jhayzhone
    In a way. And it doesn't start ticking right away, it's normally delay 10 or more seconds. Mine ticked for over a year until it started given codes. As soon as it gave codes, I had it replaced under the special coverage that the 2006 model year received.
    When replaced, the ticking went away and hasn't been back since. Nearly 2 years now.
    KOT
    Jhayzhone's Avatar
    Jan 2012
    Canada
    74
    Quote Originally Posted by Kingoftypos
    KOT
    Thanks KOT for answering my question. That special coverage is only for 2006 or 2007 models too?
    Tlorenzen is offline Cadillac Owners Connoisseur
    Automobile(s): 03 CTS (Dead), 06 3.6 CTS(Sold), 07 CTS-V
    Jan 2011
    Melbourne, FL
    1,504
    Hm. I just ordered this part. Should I have just taken it into the dealership and told them? Or was it like an extended warrenty thing you had to purchase before hand?
    Apr 2009
    Ledyard, CT
    37
    9,149
    Quote Originally Posted by Jhayzhone View Post
    Nope, just the 2006 model year. Non before or after.
    Quote Originally Posted by Tlorenzen View Post
    It was something from GM, nothing needed to be bought before hand or whatever...
    KOT
    Tlorenzen likes this.
    Jan 2011
    Melbourne, FL
    1,504
    Hm. Nice. Thanks for copying that over. Although my service engine light isn't on so they probably would've said no anyways ha. It just started making noise and I didn't want to hear it ha.
    Cads4life's Avatar
    Jul 2010
    23
    311
    I replaced the solenoid,but i am still getting the check engine light. How long/far do i have to drive in order for the check engine light to go away if this is the part that is causing issues.Also any ideas on what else might be causing this code? Please respond asap. I need an emissions test next week
    Apr 2009
    Ledyard, CT
    37
    9,149
    Whenever you replace a part, any part, that caused a CEL. The code must be cleared in order for the light to turn off. Other wise at least 50 miles must be driven. Besides, the code will still be present in the computer as a History.
    Clearing codes with a scanner gets rid of them completely, Current and History.
    KOT
    74chvy glasshouse is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS 3.6 , 74 chevy caprice
    Jan 2012
    California, desert empire
    395
    ??? Is that for sure the problem??
  16. #14
    Blackberry06 is offline Cadillac Owners Member
    Automobile(s): 2014 CTS
    Mar 2007
    Olympia, WA
    33
    Was GM supposed to send that document to the owners?
    Thanks,
    Les
  17. #15
    Apr 2009
    Ledyard, CT
    37
    9,149
    Quote Originally Posted by 74chvy glasshouse View Post
    Not sure what you are asking.
    Quote Originally Posted by Blackberry06 View Post
    Thanks,
    Les
    Only the 2006 model year.
    KOT
  18. Remove Advertisements
