buying rims and need help
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 4 of 4
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, buying rims and need help in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I am looking into buying new rims for my 03 cts i have my eye on 20 inch rims but ...
    bigces435 is offline Cadillac Owners Member
    Automobile(s): 03 cadillac CTS
    Jan 2013
    21
    10
    I am looking into buying new rims for my 03 cts i have my eye on 20 inch rims but dont know if they will fit size - 20x10, 5x115 with a offset of 20mm anyone know if they will fit??
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    Quote Originally Posted by bigces435
    No they won't. You need at least a 35 offset. Also, 10" wide is pretty wide. To be 100% sure, try and stay with a 20" 8.5" wide and 35-40 offset. There are lots of rims out there. You can even go with a 5x114.3 bolt pattern if you can't find the 115. I always said I would try not to do it but the rims I found don't come 115 so I will prob go 114.3 with hubcentric rings!
    AAIIIC's Avatar
    AAIIIC is online now Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    4,153
    Re: buying rims and need help
    As Blayne said, NO, a 20x10" +20mm won't even be close to fitting.
    I'll re-post here what I've posted in other threads in which the OP clearly had no frickin' clue what they were asking...
    There are tons of websites that explain wheel fitment. Arm yourself with the knowledge and then you don't have to ask for help every time you look at another set of wheels. None of us is going to know the pertinent information off the top of our heads - you can google for it just as easily as we can. Bolt pattern, wheel width, offset, and hub bore are the things you need to know. If you’re trying to play around with wheel fitment options, you need to do some learning first. Play with this some - http://www.rimsntires.com/specs.jsp. (ET is offset.) Tire Rack also has plenty of wheel tech on their website.
    '05 Stealth Grey CTS-V, Hyper Silver Linea Corse Venetos w/Continental ExtremeContact DWs (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  5. #4
    Blayne's Avatar
    Sep 2012
    1,058
    That is a fantastic wheel guide. Best one I have seen yet. To the OP, it's not just about if it will fit in the wheel well. There are many other things they look at for fitment. You have to think about the wheel well, being able to turn lock to lock with a wider rim. Not hitting the fender and bumper when turning. Clearing the calipers. Stress on the knuckles going with a wider wheel etc. you change even one aspect at all and handling characteristics change dramatically. Like I said, if you wanna go 20".....great, but try and stay as close to a 8.5 wide and 35 offset as you can. I will say that if you need to push the limits, there are the 2 parameters to watch. Width and offset. You can go with a 9" if you like but stay at the 35 offset. Or, go with a 32 or a 40 offset, but keep the 8.5". Stay as close to the basics as you can and there won't be fitment issues and you will be happy![COLOR="Silver"]
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
