front end rattling on my 03
Results 1 to 5 of 5
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, front end rattling on my 03 in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; So I've taken my cts to 2 dealers where they looked all up under my car and could find no ...
    chumoo is offline Cadillac Owners Member
    Automobile(s): '03 CTS
    Dec 2012
    23
    6
    Questionfront end rattling on my 03
    So I've taken my cts to 2 dealers where they looked all up under my car and could find no problem. It sounds like there is a piece of metal or something like that loose in der my car in the front end. If there's even the slightest bump the front end rattles. It sounds like it has something to do with the front axle but like I said I've had it looked at a few times and they say they can't find anything loose or that would make a noise. Any help or insight would be greatly appreciated.
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    Re: front end rattling on my 03
    Anti roll bar bushings perhaps, mine has a similar rattle at the front over bumps so will be keeping an eye on this thread, but i suspect that's what mine could be!
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    I have a similar rattle but I only get in right hand turns. Have replaced sway bar bushings, sway links and a ball joint( that was loose), but still have the rattle. Front struts an mounts are good so I'm just gonna leave it be.
    pearl03's Avatar
    pearl03 is offline Cadillac Owners Fanatic
    Jul 2011
    Cobourg Ont. Canada
    53
    147
    I had a rattle that I thought was coming from front end......turns out it was a broken plate that holds up the exhaust pretty much right under the drivers feet.
    caddyshack33 is offline Cadillac Owners Fanatic
    Automobile(s): '04 CTS 3.2 5-spd Manual
    Oct 2007
    165
    Had a front end drivers side rattle that drove me crazy for over a year. No dealer could figure it out until I finally got a tech worth a damn. Turned out to be loose clips on the brake pad. The way to test it is to gently apply the brakes while going over bumps. If the rattle goes away, you've found the culprit. Easy fix.
  8. Remove Advertisements
