Starter Grinding on start
Results 1 to 3 of 3
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Starter Grinding on start in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; My 2005 CTS 3.6, recently started having an intermittent problem at start. Once in a while when turning the key ...
    Row4fun is offline Cadillac Owners Member
    Automobile(s): 2005 CTS
    Feb 2013
    Florida
    1
    My 2005 CTS 3.6, recently started having an intermittent problem at start. Once in a while when turning the key to start, the starter grinds and then stops and engine does not start. It then grinds again and stops. This will continue to repeat until the key is turned completely off. Once the key is turned off, starting seems to work fine.
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    Sounds like the starter gear drive isn't fully engaging. More likely than anything you need a new starter.
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    Re: Starter Grinding on start
    pinion gear has to much play in its bearing and its wobbling about possibly worth taking the starter off and checking the pinion shaft, if it wobbles you need a new starter.
