Subwoofer
Results 1 to 6 of 6
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Subwoofer in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hi, I got a 2006 CTS with the non bose system. I'm currently replacing the door Speakers. I also want ...
    Acdcpsp is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4 3.6 LY7
    Feb 2013
    236
    Subwoofer
    Hi, I got a 2006 CTS with the non bose system. I'm currently replacing the door Speakers. I also want to replace the factory sub any suggestions? I would like to Keep it in the rear package tray. I tried with an infinity reference sub but its too deep and the back window is in the way. I really don't want to add an amp and run wires but if it come down to it maybe.
    josney's Avatar
    josney is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS
    Dec 2006
    South Carolina
    50
    2,305
    Re: Subwoofer
    seems like some folks have been able to get a free-air sub to fit in the rear shelf, but not without some cutting. i dont think your chances are very good getting it to sound any better, especially with the factory amp. most end up with a separate amp and sub.
    curtc's Avatar
    curtc is online now Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    Try mounting from the bottom, that should be easier. And yes, power it with an aftermarket amp.
    Feb 2013
    236
    Re: Subwoofer
    I bought a box for it today and disconnected the wires from the factory sub and ran it into my new and the factory amp don't have the balls to power it. SO I will go and get an after market amp. Only issue is I need to figure out how to get the remote signal wire set up on it the after market since I'm keeping the stock deck...
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,061
    Easy...tap into a fuse in the rear fuse box under the back seat, use one that's only hot when ignition is on. You can use the stock sub wiring as your tapping point for your line out converter too.
    Feb 2013
    236
    Re: Subwoofer
    Yeah That's what I was thinking. Thanks. I'm kinda thinking about adding an after market radio and doing the DIC mod......
  9. Remove Advertisements
