Thermostat Housing and Water Pump Replacement 2003 cts
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Thermostat Housing and Water Pump Replacement 2003 cts in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Ok so I recently bought my cadillac cts 2003 and found out it was leaking coolant. so i took it ...
    eg831 is offline Cadillac Owners Member
    Automobile(s): Cadillac CTS 2003
    Feb 2013
    26
    9
    Ok so I recently bought my cadillac cts 2003 and found out it was leaking coolant. so i took it to a local shop here and they diagnosed the problem. so the outcome of it was that my thermostat housing was leaking bad and the water pump had a pin size hole. But they are trying to charge me $ 1,071 is that worth it? I need help maybe i could do this on my own?
    p.s. im a new cadillac owner and new to this site and willing to take any suggestions.
    oh does anyone know where i can get a repair shop manual for my cts for cheap or free??
    thanks,
    Eric
    pearl03's Avatar
    pearl03 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 CTS
    Jul 2011
    Cobourg Ont. Canada
    54
    147
    I have a 03 too. Had my thermostat changed .... cost over $500 to change a $20 part. The top of the engine has to be removed to get at it. There is a how to on here... just search it. One thing about Caddy's is they are well built but when they do need care it will cost...
    cabletech is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS 3.2L M35 LtPt
    May 2010
    223
    Re: Thermostat Housing and Water Pump Replacement 2003 cts
    $1000 is ridiculous. $100 tools (good tools), 4-5 hours of time (including lunch breaks), $70 (tops) in parts. It's not that hard, just time consuming.
    Hockey Nut is offline Cadillac Owners Member
    Aug 2009
    4
    Eric, how many miles on your car? Pearl03 same question. Ihave an 03 with 48,500 easy miles. I'm trying to see if our 03's have a common miles approx. when the stats and pumps begin to fail. I welcome input from any owner. thanks. Now I found my Pinion seal weeping when I changed the Mobil !.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    cabletech is correct and pearl paid a fair price
    $1000 is way too much unless there's something else going on
    CadillacAsAlways's Avatar
    CadillacAsAlways is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS 3.2L, Luxury Sport, Diamond White
    Aug 2012
    Pittsburgh, PA
    659
    I got an 03 as well. I paid $820 for timing belt, water pump, serpentine belt, spark plugs, and tensioners to be done, and it was done well by a trusted mechanic.
    Didn't get the thermostat done, but I'm kicking myself now for not doing it. The thermo isn't broken yet, but while they were in there they coulda done it for another few bucks.
    Oh well, ill do it myself this summer I suppose. It'll be a nice learning experience.
    Feb 2013
    26
    9
    I just hit 75k
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    I did my thermostat at 68k.
    Bill Martin is offline Cadillac Owners Member
    Automobile(s): 2003 CTS, 2011 Sts
    Jul 2012
    20
    A hole in the water pump? There's a weep hole to drain water that leaks around the shaft seal. If the pump actually coroded enough to have a hole in it the cooling system has been severly neglected.
    I would rate thermostat as moderately diffucult. The manual calls for disconnecting the feed and return lines to the fuel rail ( I didn't) and there is a sequence to follow when torqueing the manifold fasteners. You'll absolutely need a torque wrench to do it correctly and a shop manual will help too. I bought a factory manual on DVD from ebay, don't remember how much so it mustn't have been too bad.
    If you have the confidence and the tools you can do it yourself. Lots of good information on the site and plenty of people willing to help.
    pearl03's Avatar
    Jul 2011
    Cobourg Ont. Canada
    54
    147
    I had thermostat changed at 125 k . Car now has 152 k on it. We had a dumping of snow last night. My neighborhood with his 4 wheel drive Chevy S15 got stuck in his driveway. I put my CTS in winter mode and drove right out and gave him a wave, and I only have all season tires on. He was still trying to dig out when I came back with our Timmies.
    propninja's Avatar
    propninja is offline Cadillac Owners Fanatic
    Automobile(s): CTS
    Jul 2005
    Los Angeles
    178
    I just finished the whole proceedure on my car. The biggest hitch some of the fasteners in awkward places, mainly the lower bolt for the serpentine belt tensioner (took me three days). Had it not been for that, I could have done the job in a weekend. It's not overly complicated, there's just a lot of stuff to take off. If you attempt it bag and tag aour cables ll of your bolts and screws. believe it or not most of your cables, hoses and vacuum lines will pretty much fall back into place, (the heat fron the engine sets a lot of the various bends in place). Take your time and don't rush, and most definately have a manual at hand. You'll save a ton of cash.
    chrisc543 is offline Cadillac Owners Member
    Mar 2014
    6
    Hello I just did one on my mother in laws car and it looks to be leaking. I am going to get an inspection camera to confirm. But something strange when I took it apart is the front bolt of the thermostat housing goes straight through into the coollent passage can anyone confirm thats how it is suppose to be?
    Jmn111080 is offline Cadillac Owners Member
    Automobile(s): Cts
    Mar 2014
    36
    18
    I don't know if it's different but I just did mine and a 2005 3.6 it wasn't bad but when I changed the transmission I figure I'll change it while I was there tell you what though in a 3.6 it is in the very back of the engine it would be a pain in the ass to change if I did not do it when the tansmission was out 120for the thermostat and housing
  16. #14
    Mar 2014
    6
    yeah the 03 is quite a bit different. it is on the front of the engine and it is in between heads. have to take entire intake manifold off to get to it.
    Can anyone confirm if the front bolt hole is supposed to go through? it is open at the bottom of the threads. wondering if that is where it was leaking from.
  17. #15
    arogers260's Avatar
    arogers260 is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Luxury/Sport package
    Mar 2012
    Indiana
    722
    The oil cooler cover is known to leak and it is directly behind the thermostat housing. As far as the bolt hole goes I can't remember is it was open when I changed mine with the oil cooler.
  18. Remove Advertisements
