Need help ASAP: OBD scan tool apparently disabled alternator
Results 1 to 3 of 3
Like Tree3Likes
  • 2 Post By propninja
  • 4 Post By AAIIIC
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Need help ASAP: OBD scan tool apparently disabled alternator in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Good morning I just purchased a 2003 cts and when driving home with it the check engine light came on. ...
    FishV12 is offline Cadillac Owners Member
    Automobile(s): NONE
    Feb 2010
    Good morning
    I just purchased a 2003 cts and when driving home with it the check engine light came on. Checked the codes using my trust worthy reader which I used countless times on other cars. Now I was told by the shop I bought the car from that my scanner managed to disable my alternator and that the codes were erased but chk engine light was still on. Funny enough I checked it twice with the same result. I find that very hard to believe. Either way the codes pulled was knock circuit input low bank 1 sensor 1 and o2 sensor bank 2 sensor 2. Need help plz! At the moment they are only replacing the o2 sensor.
    propninja's Avatar
    propninja is offline Cadillac Owners Fanatic
    Automobile(s): CTS
    Jul 2005
    Los Angeles
    178
    Re: Need help ASAP: OBD scan tool apparently disabled alternator
    If you had a Tech2 scanner that the dealership and factory uses I could see that as a possibility. Thing is, code scanners only read and erase codes, they don't modify settings, (well at least mine doesn't) Chances are that your alternator died on it's own, it just happened to be after you checked codes. Personally, and this is just my opinion, i think at worst someone just wants to sell you an alternator replacement. I'd recommend a second opinion before you start throwing parts at it.
    Argent1 and Argent1 like this.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,304
    There is absolutely, positively no frickin' way an OBDII scan tool "disabled" the alternator!
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
