2003 cts oil in radiator res.
Results 1 to 9 of 9
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2003 cts oil in radiator res. in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Started to notice oil in my radiator reservor. and now the entire reservor is filled with engine oil and my ...
    garciajoaquin's Avatar
    garciajoaquin is offline Cadillac Owners Member
    Automobile(s): CTS
    Feb 2013
    74
    Unhappy2003 cts oil in radiator res.
    Started to notice oil in my radiator reservor. and now the entire reservor is filled with engine oil and my engine oil dip stick deos not measure any oil. can this be a head gasket problem or a blow head. car has only 89k.
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    You got it.....sounds like a bad head gasket. Probably broken gasket between an oil port and cooling port. A shop can do some pressure tests to verify this!
    propninja's Avatar
    propninja is offline Cadillac Owners Fanatic
    Automobile(s): CTS
    Jul 2005
    Los Angeles
    178
    Re: 2003 cts oil in radiator res.
    It could be your oil cooler, I had one to die and it dumped iol into the cooling system. it's located between the cylinder banks under the intake manifold.
    josney's Avatar
    josney is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS
    Dec 2006
    South Carolina
    50
    2,307
    yeah, i think head gasket means water in the oil, not oil in water. i agree with propninja
    Blayne's Avatar
    Sep 2012
    1,058
    Yes, it's usually the other way around but it is possible. I wasn't 100% sure about the cooler on our cars, so I didn't want to say anything about it. That is more likely the problem. Either way there are methods to test them. Testing them first will save a lot of money instead of guessing.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    A 2003 has the oil cooler in the valley of the V6 (like the other Opel motors 2.6L and 3.0L)
    in 2004 when the timing chain 3.6L engines were introduced the oil cooler was removed (or no longer needed... not sure exactly)
    the 3.2L in the 2003s is prone to coolant leaks and oil leaks from the seals that are in the oil cooler setup
    if the cooler itself is leaking that will skyrocket the parts cost of the job (but usually it's not)
    although most of the cost is in the labor to get in there in the first place there's still between $100-$200 in parts without the oil cooler depending on how much you want to replace just because you're already there
    in this case i'm not sure that the cooler is the cause of this though it could be
    i'm leaning towards a headgasket problem caused by an overheat
    is there really no coolant in the system and just oil in the coolant reservoir? (not oil and coolant mixed?)
    Automobile(s): CTS
    Feb 2013
    74
    Yes it was engine oil in my cooling system. I did my head gaskets, oil cooler, spark plugs, water pump, and new timing belt. Problem now is its misfiring from cylinder 2,4,6. I checked my timing belt but all marks line up so im going to be checking my ground cables to the coil packs.
    seliloove is offline Cadillac Owners Member
    Automobile(s): Cadillac 2003 CTS
    Jul 2014
    21
    1
    i have the same problem right now. but i know nothing about car. so i took it to the mechanic and he thinks its the radiator.
    so he's gonna remove my radiator and put a new one in, do you all think thats it?
    briggy's Avatar
    briggy is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 3.6L 2005 80,000 Miles
    Dec 2009
    Southern California
    41
    974
    The oil dee or black? If its black I would agree with the head gasket.
  12. Remove Advertisements
