Engine Swap Question
Results 1 to 11 of 11
Like Tree2Likes
  • 2 Post By neurotictim
  • 2 Post By GregL.
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Engine Swap Question in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I have an opportunity to swap my 2005 CTS 3.6 with a 2005 CTS V-8. Does anybody know if the ...
    GregL. is offline Cadillac Owners Member
    Automobile(s): 2005 CTS
    Jan 2011
    56
    15
    I have an opportunity to swap my 2005 CTS 3.6 with a 2005 CTS V-8. Does anybody know if the V8 will bolt up to a V-6 automatic transmission? I really do not want to change out the entire drivetrain because that involves the interior console opening a whole new bag.
    I have already taken the wheels, rotors, calipers, hubs, and axles and would really like the engine but do not know if it is doable.
    Thanks all. Anybody out in the northern Virginia that can help?
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    Quote Originally Posted by GregL.
    If it does bolt up the added HP will tear it and your rear diff to shreds...This won't be easy nor cheap.
    neurotictim is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V mostly stock
    Jun 2011
    Virginia Beach, VA
    461
    Re: Engine Swap Question
    I can't speak for whether it will bolt up or not, but you *should* be able to find an auto tranny out of a wrecked Vette or GTO that will bolt right up, and theoretically keep the interior modifications to a minimum. Might wanna grab the rear end out of a GTO while you're at it.
    Good luck, and keep us posted!
    Jan 2011
    56
    15
    I can also transfer the rear diff over. Thinking the exhaust will also have to transfer. Only missing link is an auto trans from a v8.. How hard can it be? Very hard actually so I am treading with caution.
    The reason this became necessary is that my valves decided to make a racket starting yesterday. Nearly 160,000 miles on this engine. I have a CTS V 2005 in my garage that has title problems so I have been swapping parts. The loudest valve seems to come from the pass. side rear area.
    Thanks.
    Jan 2011
    56
    15
    Just to clarify things I have 160,000 miles on my v6. This one has started knocking from the top end. My V8 has 70,000 miles and runs perfectly.
    Jun 2011
    Virginia Beach, VA
    461
    I'm all for a log on how you do this - I'm very interested in what it takes to make it happen - but wouldn't it be easier and cheaper in the long run to fix the title problems on the V?
    Argent1 and Argent1 like this.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,223
    Quote Originally Posted by neurotictim View Post
    ... but wouldn't it be easier and cheaper in the long run to fix the title problems on the V?
    That would be my vote. That's not to say that it's impossible to do an LS motor and automatic in a CTS, but you'd be blazing a new path that would require a lot of custom work, both mechanical and electrical. Same goes for adding a GTO (or other) diff into the mix.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    A48WillyzGuy's Avatar
    A48WillyzGuy is offline Cadillac Owners Fanatic
    Automobile(s): 2003 CTS
    Mar 2011
    Evansville, IN
    28
    294
    Even if the motor would bolt up to the trans, I wouldn't run it. The torque from the V8 will destroy it in a heartbeat. The same is true of the V6 rear end. Even the V guys blow theirs up.
    Wouldn't it be easiest to pull the motor, trans, wiring, and ecu all at once and transplant the entire thing in your car? Grab the driveshaft, diff, clutch pedal assembly and center console from the V and you'd be set.
    Jan 2011
    56
    15
    This is exactly what I plan. And I found a friend to help. He is bringing his hoist. I have the two cars side by side in the garage. Only problem now is that the valve train quit knocking. I ran the oil a bit low and added synthetic 15w50 to fill it until I could get home and do a proper oil change. A few days went by then the rattle started two days ago. The valve noise was real bad so in my panic planned a cheap fix. So after an oil change yesterday with the proper 5W30 Mobil1 it stayed knocking for a day but today I drove it around knocking but then I started it up and all the noise was gone. Only thing I can think of was dirt or gunk clogging the cam/lifter journal. Just a thought though.
    If I do attempt this I will write down the steps, take pics and keep you all updated. Thank, all.
    neurotictim and neurotictim like this.
    Mar 2011
    Evansville, IN
    28
    294
    If you decide not to, let me know. I'm planning a very similar swap and could use some parts
    J W
    J W is offline Cadillac Owners Enthusiast
    Automobile(s): CTS /CTS-V / Escalade EXT / Coupe
    Jun 2009
    583
    Pm me about what parts you need, might have some
  14. Remove Advertisements
