04 CTS check coolant level
Results 1 to 5 of 5
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 04 CTS check coolant level in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I am new to the whole forum stuff. My cts has had the same problem about two years ago where ...
    RJCCTS's Avatar
    RJCCTS is offline Cadillac Owners Member
    Jan 2013
    Brooklyn, NY
    27
    I am new to the whole forum stuff. My cts has had the same problem about two years ago where the check coolant level popped up and took it to few me hanics and one found the problem he said was the thermostat. Now it's back again could it be that the thermostat broke or is their maybe something wrong with the compute I have seen weird codes pop up few times and one mechanic told me sometimes the computer just throws codes sometimes. Thank guys
    concorso is offline Cadillac Owners Master
    Dec 2007
    5,630
    Re: 04 CTS check coolant level
    Im assuming the coolant level is fine, or you would have mentioned it?
    RJCCTS's Avatar
    Jan 2013
    Brooklyn, NY
    27
    Yea its fine so I have no idea why it would be giving me that warning.
    Any ideas of what I should look for?
    CTSVTexas is offline Cadillac Owners Member
    Automobile(s): 2005 CTS 3.6L
    Feb 2013
    Dallas, TX
    1
    Actually, I just resolved that identical problem with my O5 CTS when that message appeared on the DIC. I added more coolant to "above" the level line located on the side of the translucent reservoir. I added a lot more above the line, but still leaving plenty of room for liquid expansion when hot. Be sure to use a 50/50 water/antifreeze mix. There is a liquid level sensor in that reservoir, and it is very, very sensative when the liquid drops down to that level line. I would demand a refund from that mechanic that misdiagnosed the problem and cost you money to repalce the thermostat. A reputable mechanic would have checked the computer error code message for that DIC display, and would have read the Cadillac recommended solution.
    RJCCTS's Avatar
    Jan 2013
    Brooklyn, NY
    27
    Oh really because after fb check coolant level kept coming on my check engine came on and ever since he changed that it never happen until now but I will try what you said thank you
  8. Remove Advertisements
