Sorry, I got called out of town for a few days, could not be helped. I did unlatch and pull both connectors on ECM mounted on bracket in front of passanger side valve cover. I sprayed both sides of the connectors with electrical spray. I hooked the battery back up, turned the key to on then to start, service security and icon (padlock) on solid no click or start to engine. I returned the key to on, could not turn to off to remove key. Unhooked battery cable again. used punch in hole in bottom of steering column to turn off & remove key. Same crap. Car has been down 2 weeks now. Ray.
