Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: Need to Replace Lower Control Arms - Options?
  1. #16
    bigdawgfoxx is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS Every Option
    Jul 2008
    Tyler, Texas
    28
    516
    Re: Need to Replace Lower Control Arms - Options?
    Quote Originally Posted by SWells View Post
    Are you sure you need to replace the whole ctrl arm? Can the rubber bushings be pressed/drilled/burned out and replaced? I've done it with other cars, just not sure with the CTS.
    Well apparently the bushing does exist YET, but according to AAIIIC there might be some coming out from Revshift.
  2. #17
    Revshift is offline Cadillac Owners Fanatic
    Automobile(s): none
    Apr 2011
    Warren, MI
    258
    Quote Originally Posted by bigdawgfoxx View Post
    They are definitely coming out very soon. We are expecting to release them in the beginning of February. Pricing is not available yet.
  3. #18
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,463
    Tadaaaaa! Straight from the horse's mouth.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  4. #19
    knals's Avatar
    knals is offline Cadillac Owners Member
    Automobile(s): Cadillac Cts 03 V6 3.2L
    Dec 2012
    24
    44
    front lower control arm bushings
    i was searching for the front lower control arm bushings for my cts 2003
    anybody ever bought just the bushings?
    i found these on revshift https://www.revshift.com/shop/front-...2007-cts-v.php
    any ideas if they work? or a place where i get a better price?
  5. #20
    Snake Enterprises is offline Cadillac Owners Member
    Automobile(s): 2005 CTS 3.6L
    Oct 2012
    67
    Quick question here, I'm about to order the Revshift Control Arm Bushings for my 2005 CTS, I'm just wondering about the difference between the hard/soft polyurethane. I didn't think that Control Arm Bushings really had any effect in the hardness of the ride.
    What would be stock? I'm current running FE3 suspension with Eibach springs. I don't baby the car but I don't track it every weekend either.
    Just wanted to hear a few opinions before I checkout with my order. Thanks!
    Oh, and also, will the poly bushings squeak or moan like Poly bushings used to? Has that been fixed yet?? lol
  6. #21
    Muhammad's Avatar
    Muhammad is offline Cadillac Owners Fanatic
    Automobile(s): CTS 2005 Sports Luxury 2.8 V6
    Feb 2011
    London, England
    138
    If I am not mistaken we are talking about the part # GM25700355-LH (for Left-side). I discover that bushes on mine are worn too (I feel the metal-striking in the steering wheel) and upon inspecting very closely, I can see slight marks on the arm joint on one side. Can I not just buy the bushes only and get them changed?
    (I am unable to attach picture as I have gone to my limit of 1.89 Mb... not sure how to get rid of old attachment)
  7. #22
    CTSM is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 08' 3.6 DI Performance | 07' Lux 3.6 Volant-Borla-Vsways
    Mar 2012
    943
    Quote Originally Posted by Muhammad View Post
    Just use some free online pic hosting website and embed a JPG here
  8. #23
    956Caddy's Avatar
    956Caddy is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac Cts Black Raven
    Apr 2012
    Harlingen,Tx
    289
    Quote Originally Posted by AAIIIC View Post
    If you're not noticing any unusual handling, noises, or ride quality issues, I wouldn't worry about replacing the control arms.
    Revshift is supposedly going to be releasing bushings for all of the control arms at some point. They've done the rear upper arms, the cradle bushings, and a couple others, but haven't done the front arms yet. (Note that they only list the suspension bushings for the CTS-V, but the CTS and CTS-V use the exact same control arms, cradle, etc, so all the bushings will be compatible.)
    Even the front stabalizer bar bushings?
  9. #24
    AAIIIC's Avatar
    Aug 2007
    6,463
    Quote Originally Posted by Revshift View Post
    It wasn't quite as quick as February, but they are available now - http://www.cadillacforums.com/forums...hings-cts.html.
    Quote Originally Posted by Snake Enterprises View Post
    Yes, control arm bushings will most definitely affect impact harshness when you hit bumps. I would recommend sticking with the softer bushings unless you're pretty hardcore.
    I asked that question in the thread I linked above and they said "typically 65". I read that to mean they haven't actually measured the hardness of the factory control arm bushings. Even the firmest factory rubber bushings I've ever seen tested were only around 80A, and IMO it's unlikely Cadillac went that firm on these, so their "typically" response is probably reasonably close.
    Depends on the poly used, but there shouldn't be an issue if they're properly lubricated upon install. I haven't heard any complaints from folks that have installed the rear control arm bushings.
  10. #25
    Automobile(s): none
    Apr 2011
    Warren, MI
    258
    I asked that question in the thread I linked above and they said "typically 65". I read that to mean they haven't actually measured the hardness of the factory control arm bushings. Even the firmest factory rubber bushings I've ever seen tested were only around 80A, and IMO it's unlikely Cadillac went that firm on these, so their "typically" response is probably reasonably close. I'm current running FE3 suspension with Eibach springs. I don't baby the car but I don't track it every weekend either.
    We have actually measured the hardness of the oem bushings with a durometer. Brand new oem bushings are right around 65A (some vary by a few points depending on the design/size). As rubber bushings get old and start to dry out they get stiffer/brittle. Older bushings may be in the 70's, significantly weaker, and more prone to unwanted compression set. This is the beautiful thing about polyurethane, it doesnt dry out, get brittle, or lose its rebound.
    As long as you lube the bushings upon installation with the teflon lube that we provide then there will be no squeaks.
  11. #26
    sandalet's Avatar
    sandalet is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-2003, 3.2 automatic
    Nov 2011
    Chechnya, Grozny-City
    39
    620
    Somebody will announce the price?
  12. #27
    DopeEffect's Avatar
    DopeEffect is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 3.6L CTS, Hotchkis Sway Bars, FE2
    Jul 2012
    Dallas, TX
    27
    524
    Quote Originally Posted by sandalet View Post
    149.99 USD for the RevShift front lower control arm bushings.
  13. #28
    sandalet's Avatar
    Nov 2011
    39
    620
    Achtung! o_O
  • You may not post replies
