Ignition coils cts 3.6
Results 1 to 8 of 8
Like Tree1Likes
  • 2 Post By Kingoftypos
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Ignition coils cts 3.6 in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hello CADILLAC FORUMS users, I am new on this site, and im really hoping somebody could help me out! I ...
    CadillacFito is offline Cadillac Owners Member
    Automobile(s): 2005 CTS 3.6L
    Jan 2013
    3
    I have a 2005 3.6L cadillac cts, and I need to replace 3 ignition coils, are the ignition coils from the 3.2l, or the 2.8 the same as for the 3.6L?
    Thank you people!
    sandalet's Avatar
    sandalet is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-2003, 3.2 automatic
    Nov 2011
    Chechnya, Grozny-City
    39
    621
    Re: Ignition coils cts 3.6
    ACDELCO Part # D501C
    GM #12613057, 12629037
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,302
    2.8 and 3.6 are basically the same engine. So parts like this are interchangeable.
    3.2 is a totally different beast, so they won't fit at all.
    Why do you need to replace three coils? What ones are causing problems? Did you try swapping them to another cylinder to see if the problem follows the actual coil, or stay at the original cylinder.
    KOT
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    What about swapping them all for Accel Super Coils, or MSD's, or.........?
    Any advantage going to aftermarket ?
    Jan 2013
    3
    Looking in from the front the 3 at the right side, it would be 3 on drivers side.
    So you don`t think I have to change those 3?
    The engine misses a lot, its shaking like crazy so my mechanic said those were the ones i needed to change, if i plug them out the engine doesnt even die, if i take one out of the other side, the engine dies right away!!
    More help is appreciated
    Thanks
    Apr 2009
    Ledyard, CT
    38
    9,302
    Since all 3 problem childs are on the same side and the engine dies right away as soon as you unplug one of the three on the good side. Then my finger won't be point at the coil packs what so ever. Because, it appears that there is a timing issue with the driver side cylinders, which are even by the way, 2 4 6. 1 3 5 are on the passenger side.
    But just to be certain, swap all 6 coils to the other side. Right to left, and left to right. That is if you are able to do it yourself or with a friend who knows.
    KOT
    Argent1 and Argent1 like this.
    Jan 2013
    3
    There was an issue with the timing chains, it has 3 timing chains, but we already fixed that issue! So could it be the coils then?
    CF
    joemalone is offline Cadillac Owners Member
    Sep 2012
    68
    Quote Originally Posted by CadillacFito View Post
    CF
    Or you could have clogged actuators. This would make your car shake.that was my problem...when you changed the timing chain, you should of maybe checked the actuators as well..they clog easily due to low oil levels.
    CF
    Or you could have clogged actuators. This would make your car shake.that was my problem...when you changed the timing chain, you should of maybe checked the actuators as well..they clog easily due to low oil levels.there are 4 of them
  11. Remove Advertisements
