Results 1 to 12 of 12
Thread: 03 3.2L idles weird when at a stop light
    bigces435 is offline Cadillac Owners Member
    Automobile(s): 03 cadillac CTS
    Jan 2013
    23
    10
    when im at a stop light my cts idles weird and check engine light starts flashing and when i accelerate the flashing stops, stop again does the same then check engine light stays on. i took it to get the codes read and says it has misfire in one cylinder. Does anybody have same issue or know what it could be Thanks!
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,281
    Re: 03 3.2L idles weird when at a stop light
    What do you have for a car? The title says 03 3.2, but your profile says 04 (either 3.2 or 3.6)
    Also, which cylinder is it in? What is the exact code?
    KOT
    Jan 2013
    23
    10
    yeah its 03 3.2L and i dont remember the code number it was about 5 months i got it checked and right now i have it in the shop getting painted so wont be able to get the exact code but i think it was cylinder 3 misfire but not really sure
  5. #4
    Jan 2013
    23
    10
    The exact codes that come up were misfire on cylinder 1, 3, and 5 we did a compression check and all six are good
  6. #5
    Mar 2010
    Detroit, USA
    12,711
    I'm sorry to hear about your misfired concerns, bigces435! I see you're already getting great DIY feedback from other owners, and I'm available if you would ever like assistance working with your dealer. Email me anytime at Katie_Lucille@gmexpert.com and I can look into your frustrations further!
    Katie
    Cadillac Customer Service
  7. #6
    Bill Martin is offline Cadillac Owners Member
    Automobile(s): 2003 CTS, 2011 Sts
    Jul 2012
    20
    For a misfire I would look at plugs then coils.
  8. #7
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    Doesn't an 3.2 have 'coil packs' ? If a coil pack went bad, it would affect the corresponding bank of 3 cylinders.
    Correct me if I'm wrong.
  9. #8
    Apr 2009
    Ledyard, CT
    38
    9,281
    Quote Originally Posted by Argent1 View Post
    With out seeing one, I am assuming that they still have it's own coil above each cylinder. It just happens to be in one package. So in theory, one coil can go bad while the other two are good. The bad part about this type of packaging, you have to replace the entire part, even though the other two coils are good.
    KOT
  10. #9
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,463
    I agree with Bill Martin. How many miles are on the car, bigces, and when was the last time the spark plugs were changed?
    For those that know more about the 3.2L than I do, how is the ignition system wired on that car? Is there one coil pack to feed each side of the engine? The fact that bigces has misfires on 1, 3 and 5 makes me think the coil feeding that side of the engine is bad.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  11. #10
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    the 3.2 has 1 coil pack for cyl 1,3,5 and 1 pack for cyl 2,4,6
    its most likely 1 of your coil packs.. i think they are about $100
  12. #11
    Jan 2013
    23
    10
    It has 115k miles, spark plugs where changed when i did the compression check. I have already taken it to an electrician and he said the same thing the coil pack he pulled it out and it was bad so we changed it and seem to fix it but a couple hours later it burnt out again he tried to find out what caused it to burn out but couldn't find the problem i really dont have a lot money to take it to the dealer so any help is good
  13. #12
    sandalet's Avatar
    sandalet is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-2003, 3.2 automatic
    Nov 2011
    Chechnya, Grozny-City
    39
    620
    Have you changed the coil on the new one?
    Order the new coil for cylinders 1,3,5 (passenger side). And we'll tell you how to change it in the home.
    If that does not help you should consider revision motor wiring.
    It also makes sense to check system voltage
  • You may not post replies
