Antifreeze smell ? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Antifreeze smell ? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Glad to hear everything was resolved with the water pump replacement, kellerk23. To those who are also experiencing this: if ...
  1. #16
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,697
    Re: Antifreeze smell ?
    To those who are also experiencing this: if you would like for us to check into anything further for you, please don't hesitate to contact us via private message here on the forum or at katie_lucille@gmexpert.com (include your name and contact information, the last 8 digits of your VIN, and a brief summary of the concern for Katie).
    Sarah (Assisting Katie), Cadillac Customer Service
  2. #17
    CadillacAsAlways's Avatar
    CadillacAsAlways is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS 3.2L, Luxury Sport, Diamond White
    Aug 2012
    Pittsburgh, PA
    659
    Quote Originally Posted by Argent1
    You don't have a Timing Chain, BTW.
    Okay. Belt. 3.2 has the belt, 2.8 and 3.6 have the chains. I know...I've just never got up close and personal with them so I tend to easily interchange the two terms despite that surely being very incorrect as one is a rubber belt and another a metal chain...just seems like a technicality to me.
    Anyway...
    When getting the water pump and timing belt swapped, should I get the tensioner done too? My brother had his beloved Jetta VR6 destroyed when something with the tensioner failed around 110,000 miles. Kinda wanna avoid that unless it isn't usually a big concern on the 3.2L engine?
  3. #18
    Bluehaze07's Avatar
    Bluehaze07 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS
    Apr 2009
    Honolulu, HI
    1,395
    Quote Originally Posted by CadillacAsAlways
    Anyway...
    My recommendation is to replace the timing belt, tensioners and Guides so you don't have to worry about it later on down the line. But I haven't heard much from 3.2 owners about timing belt failure.
    You can check to see if they are worn once you are in there and pick some up from the dealer if you need it.
  5. #19
    Aug 2012
    Pittsburgh, PA
    659
    Quote Originally Posted by Bluehaze07
    Do you mean to say you haven't heard much about tensioner failure from the 3.2L owners? Because I thought timing belts going out was an issue with the 3.2 after 100,000 miles.
    Anyway thanks, ill definitely take that into consideration. Hopefully it's all being done this week.
  6. #20
    arogers260's Avatar
    arogers260 is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Luxury/Sport package
    Mar 2012
    Indiana
    722
    I haven't heard or seen much about the timing belt failing for the 3.2 I'm at 140k on original belt still.
  7. #21
    Bluehaze07's Avatar
    Apr 2009
    Honolulu, HI
    1,395
    Hmm...I'm assuming they are synonymous when both issues will kill your engine lol. If you are not concerned about the belt, then leave the belt on if it looks good, then, Change out the tensioner without having to worry about the timing marks being reset correctly on your engine (the timing chain DIY with the million pictures helped make sense of the two guides all data had for the 3.6).
    My mechanic and i agreed that the chain looked serviceable when we were in there but I changed it along with the guides and tensioners as a preventative measure .
  8. #22
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    Just check the timing belt tensioners and idlers when you do the belt. I felt all of mine when I replaced the belt and no issues. Just rotate slowly feeling for binding, looseness, or dead spots in the bearings.
  9. #23
    Must9450's Avatar
    Must9450 is offline Cadillac Owners Member
    Automobile(s): Platinum ice tricoat. 2016 SRX Premium
    Jul 2006
    Minooka,IL
    44
    Glad you got it fixed. I have an 06 Cts 3.6 with 40000 miles and had the exact same problems.Just replaced the water pump. Very easy to do.
  10. #24
    H2K's Avatar
    H2K
    H2K is offline Cadillac Owners Member
    Automobile(s): 2007 CTS 2.8
    Oct 2011
    Florida
    39
    46
    Is the water pump leak noticeable?
    does it leave a puddle on the floor?
  11. Remove Advertisements
