hid lights
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Like Tree1Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, hid lights in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Ok so i just replaced my little triangle lights with some leds and i also added strip leds in the ...
    Jaxle67's Avatar
    Jaxle67 is offline Cadillac Owners Member
    Automobile(s): 2004 cts
    Nov 2012
    savannah ga
    95
    hid lights
    Ok so i just replaced my little triangle lights with some leds and i also added strip leds in the lower grill. They look very nice but doesn't match headlights at all. My question is can you install aftermarket hids in the stock headlight housing if the car came with regular halogens. I'm sure its been covered before but I'll give it a try. Thanks Jesse
    Bluehaze07's Avatar
    Bluehaze07 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS
    Apr 2009
    Honolulu, HI
    1,395
    Quote Originally Posted by Jaxle67
    Yes. Ddmtuning.com is where i got my set or use a vendor from the forum for HIDs. use this link to verify which bulb you need https://www.sylvania.com/en-us/appli...s/lrgmain.aspx it will be the bulb replacement guide.
    Finally. Make sure you research this a bit (forum search or even google) if you plan to install this yourself. Be prepared to take the bumper off.
    Jaxle67's Avatar
    Nov 2012
    savannah ga
    95
    thanks for the reply. Ive looked into a few kits and ive decided on a 6000k kit. I am very mechanically inclined and should have no problems with the bumper or wiring. I just was wondering was it a drop in installation our did you have to modify the stock headlight housing. I've owned some cars that were quite difficult to work on but I've never seen one that you have to go through so much for something a simple as a light change. What color are your hids? Do you have them high and low beams? How about the fogs? Jesse
    Bluehaze07's Avatar
    Apr 2009
    Honolulu, HI
    1,395
    No problem. I originally had 6000k HIDs for my lows too but, I recently swapped headlights and changed to 8,000k. I don't see much of a difference in color. I have 8,000k HIDs in my fogs too. I don't have a pic with both on though. The only mod to the housing would be a 1" hole in the dust cap to route the wires through.
    CadillacAsAlways's Avatar
    CadillacAsAlways is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS 3.2L, Luxury Sport, Diamond White
    Aug 2012
    Pittsburgh, PA
    659
    Quote Originally Posted by Bluehaze07
    Would you describe the 6000k as a pure white with a slight bluish tint, or is it distinctly a blue shade? I'm looking for the first, since im going after the Audi/BMW/2nd gen CTS color HIDs.
    SHORTSTACK's Avatar
    SHORTSTACK is offline Cadillac Owners Connoisseur
    Automobile(s): 07 CTS 3.6
    Nov 2010
    York, South Carolina
    38
    1,484
    Re: hid lights
    5k would be the purest of white. Its a plug and play system and DO NOT go to ddm, their customer service is not worth the hassle of their prices at all. Clearview is where i got mine, (i had ddm until they wanted the entire set up, ballast, bulb and wiring for a bulb warranty claim). I have had no problems with them ever since. you will not have to modify any part of the housing to get them to fit properly.
    josney's Avatar
    josney is offline Cadillac Owners Connoisseur
    Dec 2006
    South Carolina
    50
    2,307
    Re: hid lights
    6000k is not pure white, they have a slight blue tint. i have 4300k now and they are pretty frickin white
    Aug 2012
    Pittsburgh, PA
    659
    Okay, so I'm thinking I'm leaning towards closer to 5000k then. What about the lights that come with aftermarket headlight sets? I was looking at a set of halo CCFL headlights since my current ones are also hazy, and the halos look great. But are the HID kits that come with these aftermarket headlights total junk? Or what?
    Bluehaze07's Avatar
    Apr 2009
    Honolulu, HI
    1,395
    Quote Originally Posted by CadillacAsAlways
    5000k will give you more of a factory hid light output. The HID kit that came with the ccfl headlights are 8000k H7 bulb HIDs and I haven't had a problem so far. They are the ones pictured. My fogs are 8000k also and they match. Check out my thread of my headlight swap to get a better look at the kit and the headlight. I believe the HIDs included a inline resistor too. http://www.cadillacforums.com/forums...install-2.html
    SHORTSTACK's Avatar
    Nov 2010
    38
    1,484
    Re: hid lights
    As i said before, the more (higher kelvin temp) the less actual light output. Color = less ability to cast a shadow. At night shadows is what we count on for visibility... Id rather be able to see shyt at night then look cool.
    Argent1 and Argent1 like this.
    Bluehaze07's Avatar
    Apr 2009
    Honolulu, HI
    1,395
    Quote Originally Posted by SHORTSTACK
    ^^Wurd^^
    SHORTSTACK's Avatar
    Nov 2010
    38
    1,484
    Re: hid lights
    But then again I live in the country and its pretty dark. The blue lights look good, I might change them eventually and put 100w hid's in the high beams. That would be plenty of light at night.
    Bluehaze07's Avatar
    Apr 2009
    Honolulu, HI
    1,395
    I had a friend that had 75w HIDs on his truck. they were super bright. I almost thought the sun came back up...I wonder what the 100w HIDS would look like.
  16. #14
    SHORTSTACK's Avatar
    Nov 2010
    38
    1,484
    Re: hid lights
    When i gt them ill let you know. I might change the fogs and lows to a 55 watt. My wife is complaining that she cant see that good at night.
  17. #15
    josney's Avatar
    Dec 2006
    South Carolina
    50
    2,307
    Re: hid lights
    100w hids: attached image
  18. Remove Advertisements
