Where is fuel injector #1? Getting P0201 and P0301 - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Where is fuel injector #1? Getting P0201 and P0301 in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Didnt fix it. Still get the same codes. Guess its the wiring then?...
  1. #16
    hey8you's Avatar
    hey8you is offline Cadillac Owners Fanatic
    Automobile(s): 2014 Dodge Charger R/T, 2005 CTS, Gone, given to dad!
    Aug 2009
    Roseville, Ca
    38
    329
    Re: Where is fuel injector #1? Getting P0201 and P0301
  2. #17
    hey8you's Avatar
    Aug 2009
    Roseville, Ca
    38
    329
    Checked the wiring between the injector and the wire conector on the manifold. It seems ok. Does that mean ecu problem?
  3. #18
    hey8you's Avatar
    Aug 2009
    Roseville, Ca
    38
    329
    one other thing i forgot to add. there was a little bit of oil in my intake tube. i also noticed there was oil on the fuel injector. no other injectors had signs of oil on it. maybe i can try to change that spark plug?
  5. #19
    hey8you's Avatar
    Aug 2009
    Roseville, Ca
    38
    329
    Took the car to the dealer yesterday. Today they called back. Looks like I need a new ECU and fuel take pressure sensor. $1700 whoo hoo.
  6. #20
    birolziggi's Avatar
    birolziggi is offline Cadillac Owners Member
    Automobile(s): 05 cts hi feat,2011 srx lux,2011 cts performance
    Mar 2010
    rochester ny
    45
    46
    hey8you i have exactly the same problem on my 05 3.6 cts.its doing it for 2 months. they first changed the pcm then the plug and coil for #1. still same po201 .i put some injector cleaner still same .it doesnt do it everytime sometimes in the morning and sometimes during drive .horrible shake.always same code .i dropped it off at the dealer . they think it could be wiring to the injector or the injector.it was already in the shop 5 times .i have another 05 cts never did this ,neither my2011 cts nor my 2011 srx.this is soo frustating. i started thinking to get rid of it if they cant fix it this time
  7. #21
    hey8you's Avatar
    Aug 2009
    Roseville, Ca
    38
    329
    I wonder why they didn't already check the wiring.
    I understand your frustrations. I have been chasing a clicking noise for about a year. Spent a lot of money on replacement parts for the suspension and a few hours installing them. I ended up asking the dealer to look into it and it turns out it maybe my K&N filter making contact with a metal piece.
  8. #22
    ngoodnight01 is offline Cadillac Owners Member
    Automobile(s): 04 CTS
    Oct 2012
    35
    26
    You could buy the PCM yourself and the Drew tech doggle and a 55$ sub to ACdelcoTDS and take care of the PCM yourself.
  9. #23
    hey8you's Avatar
    Aug 2009
    Roseville, Ca
    38
    329
    Quick search of Drew tech shows its $1680.00 just for the unit. Is that the same thing a as a tech II? Probably would have been cheaper to just buy a pcm and have the dealer reprogram it. My CTS is also my DD and I didn't want to rent a car until I got the parts. I miss having 2 cars.
  10. #24
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    birolziggi -
    Any news from your dealership? If you want for us to do any follow up for you, please let us know as we'd be happy to check into this further. We can be reached either via private message or email (katie_lucille@gmexpert.com) and ask that you would please include the last 8 digits of your VIN and a brief summary for us to get started.
    Sarah (Assisting Katie), Cadillac Customer Service
  11. #25
    Oct 2012
    35
    26
    http://www.ebay.com/sch/i.html?_odkw...goose&_sacat=0
    Buy the mongoose cable and sub from ACDELCOTDS.com and it can be done for under $600 plus parts
  12. #26
    hey8you's Avatar
    Aug 2009
    Roseville, Ca
    38
    329
    Thanks for the link. I'll keep this in mind next time.
  13. #27
    birolziggi's Avatar
    Mar 2010
    rochester ny
    45
    46
    finally got the car back today.after two dealerships they found the problem.wiring from the ecm to the injector was shorting . bad connector.they also flushed the tranny .so far so good
  14. Remove Advertisements
