Radio not working
Page 1 of 2 12 LastLast
Results 1 to 15 of 27
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Radio not working in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; i replaced the antenna module in my wife's 2003 cts with a used one i purchased off of ebay and ...
    wingnut2000 is offline Cadillac Owners Member
    Automobile(s): CTS
    Jul 2010
    34
    53
    Radio not working
    i replaced the antenna module in my wife's 2003 cts with a used one i purchased off of ebay and now the am and fm are not working. The keyless entry has stopped working as well. The Fm radio did not work before the swap but the am radio did and the keyless did and now nothing is working. What could this be? a fuse? should i reinstall the old one to get the keyless entry back to working? Its not a fun process taking the car apart to fix this.
    Automobile(s): CTS
    Jul 2010
    34
    53
    Re: Radio not working
    anyone?
    Teedoe's Avatar
    Teedoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Base and 2014 Cadillac CTS VSport Premium
    Dec 2009
    Central Florida
    527
    Check the fuse under the driver's side back seat. Might have blown
    Automobile(s): CTS
    Jul 2010
    34
    53
    thanks i will try this. Is there a tutorial on removing back seat to expose this fuse??
    CadillacAsAlways's Avatar
    CadillacAsAlways is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS 3.2L, Luxury Sport, Diamond White
    Aug 2012
    Pittsburgh, PA
    659
    Quote Originally Posted by wingnut2000
    Pull up front edge of seat, pop it up, and remove from car. No tutorial necessary.
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,254
    Buckle the seats belts first. It'll make for finding the seat belts easier when you put the seat back in.
    KOT
    Automobile(s): CTS
    Jul 2010
    34
    53
    thanks. i will let you know how it goes
    Automobile(s): CTS
    Jul 2010
    34
    53
    I checked the fuse and it was fine. Dunno what to do now. I guess the antenna module i bought could be bad.
    Automobile(s): CTS
    Jul 2010
    34
    53
    any ideas?
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    it's possible that it could be a bad module
    but more likely than that is it needs to be programmed to your vehicle (vin programming) before it will work
    what's the part number?
    Automobile(s): CTS
    Jul 2010
    34
    53
    I know now that the remotes will have to be programmed but will they need to do programming for the radio to work?
    the part # on the one i bought used is 12233252
    Apr 2009
    Ledyard, CT
    38
    9,254
    What fuse did you check? The TRUNK DR RELEASE 10amp is the fuse that takes care of that module.
    But if I were you, I would check all fuses no matter what they say.
    KOT
    Sep 2007
    Wilmington, NC
    13,986
    Radio Antenna Module Replacement
    Removal Procedure
    1. Remove the rear sail panels. Refer to Sail Panel Replacement in Interior Trim.
    2. Remove the rear assist handles. Refer to Assist Handle Replacement in Interior Trim.
    3. Remove the rear roof mounted dome lamp. Refer to Dome Lamp Replacement in Lighting Systems.
    4. Carefully lower the rear of the headliner to access the antenna module.
    5. Disconnect the coax cables (3,4).
    6. Disconnect the electrical connector (1).
    7. Slide the diversity antenna module  (2) off the mounting bracket.
    Installation Procedure
    1. Install the diversity antenna module (2) on to the mounting bracket.
    2. Connect all the electrical connectors (1, 3, 4).
    3. Install the rear roof mounted dome lamp. Refer to Dome Lamp Replacement in Lighting Systems.
    4. Install the rear assist handles. Refer to Assist Handle Replacement in Interior Trim.
    5. Install the rear sail panels. Refer to Sail Panel Replacement in Interior Trim.
    doesn't look like it requires programming
  16. #14
    Automobile(s): CTS
    Jul 2010
    34
    53
    i checked the trunk release fuse and all the others and none were blown.
    Thanks for the diagram wish i wouldve had that before i replaced the module. I did for get to slide the arm on the module back through the dome light hole. would that matter at all?
    i tried access the links on the diagram and it says i am not authorized to view them
  17. #15
    Sep 2007
    Wilmington, NC
    13,986
    yes those links are behind GM's service firewall (i'm surprised that the images come through actually)
    i can get you the rest of the install/removal documents form those links if you want (PM me your email address so i can send them as PDFs)
    the only other suggestion that i would have is to put your old module back in and make sure it operates as it used to operate before you put this other module in
    if it doesn't then you will know something else is going on
    also, when you installed the module did you disconnect the battery?
    i know it doesn't say to do so in the instructions above but usually when working on electronics in a car it's a good idea to have the battery disconnected
  18. Remove Advertisements
