Some issues
Results 1 to 4 of 4
Like Tree1Likes
  • 2 Post By Kingoftypos
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Some issues in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hello everyone, today I got a Magnaflow muffler and x-pipe installed on my CTS and I have a K&N cold ...
    MrR0se's Avatar
    MrR0se is offline Cadillac Owners Member
    Automobile(s): 2006 CTS 3.6L
    Dec 2012
    Virginia
    16
    Some issues
    Hello everyone, today I got a Magnaflow muffler and x-pipe installed on my CTS and I have a K&N cold air intake. (took the idea from a guy here). Anyway, when I was driving it home I noticed the engine "stuttering" and when I accelerated the Check Engine light came on, it also idled very roughly. I took it back to the shop and them told me it would take time for the computer to adjust to the new airflow. They told me to drive it for a few days to let the computer adjust and if that doesn't work then take it to Cadillac and have them reprogram. Do you guys think that's what it is? I want to make sure I check every possible solution.
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,213
    Go to Auto Zone and have them scan the car since the engine light is on.
    Then report back here.
    KOT
    MrR0se's Avatar
    Dec 2012
    Virginia
    16
    Re: Some issues
    Quote Originally Posted by Kingoftypos View Post
    KOT
    Thanks for the advice. I took it to Auto Zone and got it scanned, cylinder 1 is misfiring.
    Apr 2009
    Ledyard, CT
    38
    9,213
    Re: Some issues
    It could be just coincidence that it happen now. Most likely had nothing to do with the exhaust change at all. I don't know how your mechanical skillz are, but here you go.
    http://www.cadillacforums.com/forums...ug-change.html
    What I would do, and actually done. Is to remove the coil pack and spark plug from cylinder 1. Swap the spark plug with cylinder 5's plug. And swap the coil pack with cylinder 6's coil pack. So if it miss fires after the swap, scan it again to see where to misfire is. If it's in cylinder 5, then replace the plug. If it's in cylinder 6, then it's the coil pack. The reason why I said to swap them with cylinders 5 and 6, is because you don't have to remove the upper intake again to get to those two.
    However, if the misfire is still in cylinder 1. Then there are other problems, such as fuel injector.
    KOT
    Argent1 and Argent1 like this.
  7. Remove Advertisements
