code p2119 & p2176 "engine power reduced" on screen & tcm light on dash.
Results 1 to 2 of 2
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, code p2119 & p2176 "engine power reduced" on screen & tcm light on dash. in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; replaced the crank sensor months ago due to car not starting, car worked amazing after. ever since the beginning of ...
    CADDYPRINCESS's Avatar
    CADDYPRINCESS is offline Cadillac Owners Member
    Automobile(s): cadillac cts 03
    Jan 2012
    27
    53
    replaced the crank sensor months ago due to car not starting, car worked amazing after. ever since the beginning of this month the car would turn off while driving. replaced the cam sensor yesterday car ran perfect. today all of this happened now... what would it be now? i called the dealership and they could care less of giving advice and just suggest having them look at it for 125 dollars. i understand these codes are either the throttle or the wiring or ecm. please help this car has a serious case of being a lemon lol
    where do i start to check the problems?
    i am very overwhelmed with this car and i searched it on here already and nothing clicked. any helpful links would be appreciated too
    cabletech is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS 3.2L M35 LtPt
    May 2010
    223
    Re: code p2119 & p2176 "engine power reduced" on screen & tcm light on dash.
    Looking at the Helm manual... it appears those codes are both related to the throttle blades not closing all the way, or the ECM not being able to detect the throttle blades being closed. A couple of options worth exploring - one would be the throttle relearn procedure (search here), the other would be pulling your intake ductwork and looking at the throttle body closely to make sure there are no obstructions or oddities about it. How's the car idling when parked and warmed up?
