Crank position sensor oring...
Results 1 to 5 of 5
Like Tree1Likes
  • 2 Post By jran0823
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Crank position sensor oring... in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; '03 CTS Crank position sensor oring leak. Does anyone know the part number or dimension of the oring? I have ...
    Lade in AK's Avatar
    Lade in AK is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac CTS Base-Auto
    Oct 2005
    El Paso, TX
    156
    '03 CTS
    Does anyone know the part number or dimension of the oring? I have replaced it twice without success. The crank position sensor has about 20k miles on it.
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    Get a GM crank sensor, the aftermarket ones are slightly different and allow the o ring to roll and tears it on installation because the sensor is different than the OE Bosch sensor.
    Lade in AK's Avatar
    Oct 2005
    El Paso, TX
    156
    Re: Crank position sensor oring...
    So, for the oring, does it go on the sensor after the spacer, or on top of the spacer?
    From the pictures on rock auto, which aren't very clear, it seems as if the oring is installed on top of the washer/spacer.
    jran0823's Avatar
    Apr 2011
    GB, WI
    30
    1,017
    There should be a seat for it on the sensor. The OE sensor has a collar before the o-ring to keep it from rolling it when installing the sensor where as the aftermarket ones don't. Another reason to get the OE sensor is it is cheaper than the aftermarket one I got, and the only reason I got a aftermarket sensor was it was a Sunday and the dealership was closed. I returned the aftermarket sensor the next day as a defective part, because it leaked oil like a siv.
    Argent1 and Argent1 like this.
    Lade in AK's Avatar
    Oct 2005
    El Paso, TX
    156
    i replaced the oring and actually put the new one around the collar instead of next to it. Minimal oil leaking so far. Gonna have to clean the area well to make sure it's not just residue.
  8. Remove Advertisements
