3.6L waterpump and belts replacement guide??
Results 1 to 2 of 2
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 3.6L waterpump and belts replacement guide?? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; going to change my waterpump and 2 belts is there a guide and what tools do i need? thx...
    wantboost is offline Cadillac Owners Fanatic
    Automobile(s): '06 CTS 3.6L:HID HEADLIGHT/FOGS:LED INTERIOR/PLATE/TRIANGLE:
    Oct 2010
    GTA
    343
    thx
    ztollon's Avatar
    ztollon is offline Cadillac Owners Enthusiast
    Aug 2012
    629
    Remove intake from tb, take off both belts w a 3\8 drive ratchet or breaker bar. Drain coolant, i belive its six bolts for tge water pump. Comes right off. New gasket and pump. I wanna say they are supposed to be torqed to like 18 ftlbs. And then fill the coolant back up threw the upper intake hose to make sure u get rid of most the larger air pockets. Start the car. Obviously aftrr installing the belts and intake, leave rad cap open turn the heat in the cabin on full blast and wait for the heat to blaze. After that you may have to top off the fluid but i did mine in about an hr er two
