Power mirror wires (where do they go)
Results 1 to 3 of 3
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Power mirror wires (where do they go) in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I am trying to find the retained access power (RAP) for my car but that turned out to be too ...
    ejn
    ejn is offline Cadillac Owners Member
    Automobile(s): None
    Sep 2012
    14
    I am trying to find the retained access power (RAP) for my car but that turned out to be too difficult so instead I think I might be able to grab power from my review mirror. I found the wire from the harness at the mirror which comes on while the RAP is on (ie. when the key is turned on until the key is removed and the door is opened). It is the gray wire, fourth from the left on the bottom row. Only problem is that I do not know where this wire goes. It goes off into the headliner which I would rather not take down. Is there anyone that knows where this harness ends up so that I could run it from there up to the stereo? Also, how many amps can it supply and would it be necessary to put in a relay in order to provide more amps? I have searched the forums up and down for the answer but I am unable to find the answer if it is here. Here is the wire harness in case it helps.
    Thanks,
    Erik
    ejn
    Automobile(s): None
    Sep 2012
    14
    Re: Power mirror wires (where do they go)
    Well I tried this thinking it should work just fine (I used a relay in case it drew too many amps). However, it didnt work as expected. Instead it turns on whenever I open or close the door, even with the door closed. It only gets power for 10-20 seconds but every time the door opens. The strange thing is that my multimeters read 0 volts, like I had wanted. Does anyone have any idea why it might do this?
    Did I hook something up wrong or is the CANBUS or something screwing up the mirror signal? Any ideas? Thanks.
    ejn
    Automobile(s): None
    Sep 2012
    14
    OK, I figured out the problem and everything works like I wanted it to.
    Problem was the steering wheel controller (PAC SWI-RC). It said to tap switched power from the purple wire on the stock radio. That seemed to cause a problem since I had the new deck's switched power connected to this too in a round about way (through the DVD bypass relay). I moved it to my "RAP relay" and now everything works correctly.
