Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Stalling *
    Nov 2012
    40
    4
    Stalling *
    I was driving on the highway today, upon trying to exit the highway I slowed down and my 2003 CTS stalled. No power. I pulled over, it stayed off for about 10 minutes, after that it restarted.
    I drove it another 5 miles an it stalled again. My battery seemed to be charging fine, while parked battery was at 11.8 - 12 volts and in the 13's while it was on.
    Any ideas what it can be?
    Crank Sensor? Alternator? Bad battery?
    This sound familiar to anyone else on here
    Thank you in advance.
    erdoc48 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 SRX Performance FWD, Platinum Ice
    Dec 2005
    Westampton, NJ
    218
    Re: Stalling *
    Questions for you:
    - when lights are on, are they dim?
    - when charging, I believe the charging voltage should be closer to 14 volts
    - does the car seem to not have enough cranking current when starting the car?
    - how old is the existing battery?
    - any CELs?
    Just a few thoughts that might indicate need for a new battery
    josney's Avatar
    josney is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS
    Dec 2006
    South Carolina
    50
    2,305
    Re: Stalling *
    crank position sensor is your problem, seeing you have an 03, thats your problem. you can pick one up for about $40-50 bucks and depending on your skills, it can be done pretty easily.
  5. #4
    s_tharsan's Avatar
    s_tharsan is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS Sport
    Aug 2009
    Toronto, ON
    29
    260
    Re: Stalling *
    Can this also not be a malfunctioning alternator? Cause this happened to me in another vehicle once and it was the alternator.
    Quote Originally Posted by josney View Post
  6. #5
    Nov 2012
    40
    4
    Re: Stalling *
    No dimming.
    voltage in park is about 13.9v
    car will crank and without any luck, given 10 minutes with car off, it cranks fine.
    Existing battery is original to me since I bought it with about 16K on it. Guessing its the original from factory.
    There is a CEL but did not grab numbers. I'm sure one is O2 sensor (non related)
    It seems it rechrges, I drive it and it quietly dies while driving, especially upon deceleration ( may be a coincidence) Only happened twice before towing.
  7. #6
    s_tharsan's Avatar
    Aug 2009
    Toronto, ON
    29
    260
    Re: Stalling *
    How many km do you have on the car. I once owned a car that would die all the time. I pull the battery out and left it over night and it would keep its charge. But in the end I found out it was still the battery doing weird stuff. Changed the battery and the car was fine.
    Quote Originally Posted by Nunob77 View Post
    No dimming.
  8. #7
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,277
    Re: Stalling *
    I am gonna agree with josney... Crank Shaft Position sensor.
    KOT
  9. #8
    josney's Avatar
    Dec 2006
    South Carolina
    50
    2,305
    Re: Stalling *
    if you try to start the car and the starter just cycles for a few seconds, but will never start, its the CPS. i am willing to bet the farm. wait, i dont have a farm. but if i did, i would bet it anyway. we typically get about 4 or 5 a month around here, very common for 03's.
  10. #9
    Apr 2009
    Ledyard, CT
    38
    9,277
    Re: Stalling *
    Then the 10 minute wait, classic symptom.
    KOT
  11. #10
    Nov 2012
    40
    4
    Re: Stalling *
    This exactly IT with the 10 minute wait. I'll let my mechanic know what I think it is and he'll take care of it.
    Thank you.
    Car has 79K
  12. #11
    josney's Avatar
    Dec 2006
    South Carolina
    50
    2,305
    Re: Stalling *
    thats was about the time mine took a dump....80,000 mile mark. just be prepared that some mechanics "may" not believe you. I had several buddies of mine say there was not way flushing the heater core would solve my heat problems years ago, but to this day, no problems. so, just be prepared for another diagnosis
  13. #12
    Nov 2012
    40
    4
    Re: Stalling *
    I told my mechanic I thought it was the Crank Shaft Position sensor... he responded with "how do you know it is the Crank Shaft Position sensor?" So i fully expect it.
    Will get an update here soon.
  14. #13
    Apr 2009
    Ledyard, CT
    38
    9,277
    What was your answer to his question?
    A few years ago, I remember a Cadillac dealer replacing a bunch of stuff. Fuel pump and filter, ECM and whatever else. The member came on here, gave us the symptoms and we told him crank shaft sensor. He tells the dealer, despite not believing him they replaced it. Days, weeks and months went by with no problems. The dealer was dumb founded and took it as a learning experience. Thankfully, the work was done under the members extend warranty.
    KOT
  15. #14
    danielfilteau is offline Cadillac Owners Member
    Automobile(s): cts 2003
    Dec 2012
    montreal
    12
    Re: Stalling *
    my 03, 3.2 l. has the same problem but I have to wait about an hour before it restarts. All electrical looks normal. ther are no codes on the ecm. how can you know if it's the cps or fuel system if ther is no codes? thanks.
  16. #15
    josney's Avatar
    Dec 2006
    South Carolina
    50
    2,305
    Re: Stalling *
    mine gave no codes. just the symptoms given above
  • You may not post replies
