2003 cts keyless entry doesnt work - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2003 cts keyless entry doesnt work in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Originally Posted by voodoochikin04 ok, well if that antenna module was the culprit, wouldnt it NOT work? i mean, why ...
  1. #16
    arogers260's Avatar
    arogers260 is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Luxury/Sport package
    Mar 2012
    Indiana
    722
    Quote Originally Posted by voodoochikin04
    ok, well if that antenna module was the culprit, wouldnt it NOT work? i mean, why would it work untill right when the amp in the trunk clicks? I just feel that something is shutting off power.. Id love to study the actual wiring diagram and trace where wires run. but i dont have a wiring diagram.
    I posted a link to access chitons online database and there r some wiring diagrams on that site. Just follow the instructions I posted it under chiltons manual.
  2. #17
    voodoochikin04 is offline Banned
    Automobile(s): 2003 cts, 2004 Cts-v
    Nov 2012
    Norfolk, NE (eastern Nebraska)
    31
    316
    Re: 2003 cts keyless entry doesnt work
    thanks!
  3. #18
    Nov 2012
    31
    316
    So Ive been pouring over the wiring diagrams for my car. I can track all the wiring from the trunk dr release fuse, right up to the antenna module and there are no relays or anything that should affect it. but i have a hard time believing my problem is a bad antenna module, when the scenario is the same everytime.. 22-25 seconds after i lock or unlock (time starting after the last key fob button click)... the amp in the trunk clicks, and my fob doesnt work any longer. to me that screms that power is being cut off to it. Yet i still have 12volts at the trunk dr fuse. im about ready to pull my hair out..
  5. #19
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    394
    Pull down the rear of the headliner and unplug the connection at the module and probe for constant voltage from there, just as a test.
  6. #20
    Nov 2012
    31
    316
    ill try to get that done tonite.
  7. #21
    Nov 2012
    31
    316
    well i tried for two hours last night to get my headliner down enough to get to the power clip on the antenna module. The headliner is glued to the metal roof right at the back on my car. You pull and it pops the metal roof in and out. Also the power wire to the module is only about 4inches long coming out of a main harness that is completely covered in glue to the headliner. Not only can i not see the power wire clip, you cant even slide the antenna module out of the clip that holds the whole unit to the headliner because of this short cord. BUT- i found the plug behind the drivers sail panel that when unplugged, kills my keyless entry from working at all.. I test all those wires and found that none coincided with the click in the trunk. The power wires always have power. SO im not sure where to go now. I honestly dont believe that the antenna module is bad because it is consistent when it works and doesnt work. its freakin clockwork. doesnt make sense. IT really feels like a setting or something thats controlling it.
  8. #22
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,149
    Wow... I was able to remove my headliner. Yeah I saw the glue, but it wasn't nearly as bad as yours.
    Go aftermarket is all I can say.
    KOT
  9. #23
    Nov 2012
    31
    316
    yea im gonna have to agree... its not worth tearing my car to pieces and ruinging things. I appreciate everyones advice and help. THANKS
  10. #24
    caddy-los is offline Cadillac Owners Member
    Dec 2012
    6
    I have the same problem took my CTS to the dealer and they said that the antenna module is cutting it's self off and needs to be replaced....
  11. #25
    Nov 2012
    31
    316
    let me know if that fixes it when you replace that module.
  12. #26
    Dec 2012
    6
    Don't think I'm going to do it right now it over 400$ for it
  13. #27
    hrpatel17926 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS, 2007 ESV
    Sep 2012
    The city of the 500
    46
    263
    voodoo,
    Buy yourself a $100 remote starter kit and call it a day, you have the entire car torn appart for all the wiring anyways and you will have a greater distance than stock and have remote start...
  14. #28
    Nov 2012
    31
    316
    yea thats my plan... im just curious if dude replacing his attenna module will fix it..
  15. Remove Advertisements
