Window belt molding removal.
Results 1 to 8 of 8
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Window belt molding removal. in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Anyone know how they come off on the CTS rear doors? Do they just pry up like older GM cars? ...
    nopi08 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Jan 2008
    158
    Anyone know how they come off on the CTS rear doors? Do they just pry up like older GM cars? Getting the door ready for paint.
    Bluehaze07's Avatar
    Bluehaze07 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS
    Apr 2009
    Honolulu, HI
    1,395
    Quote Originally Posted by nopi08
    Are you talking about the interior door panel? It is pretty simple if you are. The door panel has two screws under the wood handle you use to pull the door close. Use a flat blade screw driver or panel removal tool to pry up the cover for the screws. (You will see what I'm talking about). Remove the two philips head screws and then pry up the edge of the bottom of the door panel. (Be careful). Pry up on the sides next and lift the panel up (not pull out) from the top of the door. Then you should be done. Someone chime in if I forgot anything.
    Jan 2008
    158
    Re: Windo belt molding removal.
    Quote Originally Posted by Bluehaze07 View Post
    No I am talking about the window belt molding on the outside of the door. Its the little rubber molding that sits on the door and the outside of the window. It rather remove it than tape it up but i dont want to just pry it up without checking first.
    Jan 2008
    158
    BUmp anyone know?
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    I'd say go to a local body shop and ask, I am sure they would know. That's something that is usually only done for painting.
    Bluehaze07's Avatar
    Apr 2009
    Honolulu, HI
    1,395
    BUmp anyone know?
    There are links to the vehicle maint/repair manual in the stickied DIY SECTION. You may be able to find out how to remove it from there if no one else can tell you how.
    ShapeShifter's Avatar
    ShapeShifter is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS Sport w/Wheel Performance & Sport Appearance Pkgs
    Jan 2012
    SE Michigan
    64
    807
    Sounds like your talking about the Front Door Outer Sealing Strip. If so, these three pages from my digital 06 Service Manual tells how to remove and install the strips. A very small portion of the front of the strips extends underneath the mirrors, pretty sure that’s why the instructions require their removal so that no damage occurs to strips or mirrors. I haven’t had a need to do this myself, so please proceed cautiously as the strips look a bit delicate. (Edit: Added removal and install for rear door strip at the bottom of this post)
    There’s a diy thread on how to remove and install mirrors in FAQ DIY Sticky under the “Exterior and Appearance Modifications” heading @ http://www.cadillacforums.com/forums...w-manuals.html
    Hope this is useful.
    EDIT:
    Sorry about the earlier post showing the Front Door, but hope someone can also find it helpful.lol
    Anyway, if you wanted instructions for removal of the Rear Door Outer Sealing Strips, then these pages from the digital 06 Service Manual tells how to remove and install the strips for the rear door.
    Hope this will be more helpful.lol
    Jan 2008
    158
    Thats it. Thanks!
  11. Remove Advertisements
