Where to install DRL LEDs on a CTS - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
Like Tree2Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Where to install DRL LEDs on a CTS in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; chlapec10, I have been somewhat following this thread. So I don't have to go through all the postings again, I'll ...
  1. #31
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,211
    Re: Where to install DRL LEDs on a CTS
    chlapec10,
    I have been somewhat following this thread. So I don't have to go through all the postings again, I'll just ask this...
    How do you feel about having just the headlight, low beams of course, be on for this regulation?
    I ask, because I could figure out for you on how to do that if you like to have it like that.
    KOT
  2. #32
    chlapec10 is offline Cadillac Owners Member
    Automobile(s): CTS 2006 2.6L M5
    Aug 2012
    Slovakia (Europe)
    29
    73
    Thanks King
    Well, honestly, I would rather install the LED's to save the bulbs. They also sell DRL adapters here, that make the lights go on automatically,
  3. #33
    Aug 2012
    Slovakia (Europe)
    29
    73
    SO...
    I ordered the separate bulb set... unfortunately there was no space for it in the front bumber after I installed the parking sensors....
    Today I ordered these strips http://www.ebay.de/itm/330665228607?...84.m1497.l2649
    I will probably stick them on the bottom of the headlight or alternative on the spot between the headlight and the grill
  5. #34
    Aug 2012
    Slovakia (Europe)
    29
    73
    drl.jpgSo, they fit the bottom rim of headlights perfectly.... and it looks great as well... more photos soon
  6. #35
    bruinsfan is offline Cadillac Owners Member
    Automobile(s): 2004 cts , 3.6L
    Sep 2012
    albany new york
    38
    What did you wire them to? I purchased a set and put them right were you put yours underside of bottom headlight ran the wires between bumper but can't seem to find a wire to hook them up to. I want them to come on with my drl's. Anyone know where I can wire these strips to without using the fusebox? Thanks
    I have hid fogs and tyres to wire them somehow to the connector. Did not work, I really am not that great with wiring things but if anyone has these led strips please let me know where and how to wire them. Like I said there isn't enough wiring to go to the fuse box so I have to connect them somewhere near the fog light area behind wheel wheel.
  7. #36
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,304
    Quote Originally Posted by bruinsfan View Post
    Crazily enough, the wiring for the DRLs and fog lights is right in that area! If you want them to come on with the DRLs, it would seem to make sense to tap off the DRL wiring, which is right below where you've apparently added the LEDs. Of course, connecting to the DRL wiring means your new LEDs are going to flash with the turn signals, since the DRLs are also your turn signals. The only way to make them come on with the DRLs but not flash is going to be tapping in to the fuse box.
    If you're really not that comfortable with this project, then take the car to a stereo/alarm install shop - they should easily be able to manage it.
    Argent1 and Argent1 like this.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  8. #37
    Sep 2012
    albany new york
    38
    When you say tap off, do you mean splicing the wiring and connecting it to the wires itself? Like I mentioned yesterday I tried to wire them into the fog light hid connectors they worked but the wires which are thin as hell on the strips just came off. So basically I have to splice some wires to tap into is what your saying? Thanks for your input by the way.
  9. #38
    Aug 2012
    Slovakia (Europe)
    29
    73
    First of all, my kit also contained a DRL control module.. both strips are connected to it..
    The module is connected to power, ground and headlight (for control), this is because by law in europe DRLs have to be turned off when headlights are on and vice-versa... so when the headlights are on, it is detected by the module through the cable and it turns off the strips, when the headlights are turned off the module switches the strips...
  10. #39
    Sep 2012
    albany new york
    38
    Well I put them in yesterday but don't know if I did it correctly. I basically disconnected the connection from my hid fogs to the ballast stuck the wires in the connectors positive to positive then snapped the connectors back in and it works when I turn my fogs on. Don't know if this is the right approach but it works.
  11. Remove Advertisements
