Just installed ddm 55w hids... cut off is horrible...
Results 1 to 5 of 5
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Just installed ddm 55w hids... cut off is horrible... in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; my head lights are not the cleanest.... i recently used one of those headlight cleaning kits and they looked alot ...
    Jake1z is offline Cadillac Owners Member
    Automobile(s): 03 cts
    Sep 2012
    32
    8
    my head lights are not the cleanest.... i recently used one of those headlight cleaning kits and they looked alot better then... when i turn the lights on it seems that i have two cut off points.. one at normal level and one really high one.... i will get pics in the morning be that i just got into work (9pm).... im guessing its because my head lights are still some what foggy? any one else ever have this problem...
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,149
    Re: Just installed ddm 55w hids... cut off is horrible...
    You have to realize that you've installed HIDs into a halogen housing setup. So the cut offs will be different. Also, with left hand drive cars the passenger headlight has a higher cut off due to the light shining onto the signs that are on the right side of the road.
    My only advice is to adjust the level. There are adjustment points under the hood and in circular holes that are built into the radiator frame. You will be able to see bolts surrounded by white cones. Adjust them when you are parked in front of a blank wall.
    KOT
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    The reason you have 2 cut-offs is because the 03 projector is different than 04-07. I replaced my RF housing with one from a 04 instantly noticed the difference, so I took the housings apart and took the projector from my 03 and retrofitted it. The cut-off plate in the 03 has 2 openings machined in while 04-07 has 1. I like it because when you get that @$$hole that won't pass the car in the slow lane at night you ride his @$$ and the upper cut-off shines right into his rear view mirror(they always move over after). I've also taken apart factory Xenon housings and the projector looks identical, so I really don't know if they are different. I've also been told the CTS's factory projectors are made out of crystal instead of glass like aftermarket and cheaper ones. I'm guessing that's why GM wants $680 for an assembly.
    Sep 2012
    32
    8
    ok just did some reading turns out i have "sign spotters" that i need to cover up to stop the second cut off...
    jran0823's Avatar
    Apr 2011
    GB, WI
    30
    1,017
    You have to separate the headlight assembly, take the projector out, and the split the projector without chipping or cracking the lenses. I like the "sign spotters" personally.
  8. Remove Advertisements
