shifting issues
Results 1 to 3 of 3
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, shifting issues in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hi all, having a problem with my 2003 cts. My transmission line into the radiator busted off so my mechanic ...
    frankburg81 is offline Cadillac Owners Member
    Automobile(s): 2003 cts
    Oct 2012
    1
    someone help.... please reply
    Hi all, having a problem with my 2003 cts. My transmission line into the radiator busted off so my mechanic replaced my radiator. Now it seems like when I first start the car and put it in reverse to get out of the driveway then put it back in drive their is really no pickup when i first step on the gas... after that first gear change it does better but it doesnt shift the way it was before, it seems to rev higher now before shifting. My mechanic said it would fix itself but its been two weeks now and 200 miles later....also a few days after the new radiator was installed the power steering reservoir overflowed through the cap.. please give me some advice. Thanks
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    To me it sounds like its either low on ATF or the transmission sustained damage before. Either way stop driving it if isn't damaged yet. Find a way to get it up level and pull the fill plug on the side of the transmission. If its full there should be a very slow drip/stream of fluid when the plug is removed.
    ztollon's Avatar
    ztollon is offline Cadillac Owners Enthusiast
    Aug 2012
    629
    Which side of the trans is it?
