Results 1 to 5 of 5
Thread: Shift to reverse click?
    Rbeisaw's Avatar
    Rbeisaw is offline Cadillac Owners Member
    Automobile(s): 2006 3.6L Blackberry
    Jul 2012
    Lewiston, Maine
    33
    26
    I have an 06 3.6 with 64000 miles
    When I shift into reverse, from either park or drive, cold or warm engine, I get a click noise that comes from under the good or I should say the front of the car. It's not loud or excessive but is a distinct click. Any idea what that could be? I would say it happens 95% of the time now. I just keep waiting for it to turn into a clunk!
    CadillacAsAlways's Avatar
    CadillacAsAlways is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS 3.2L, Luxury Sport, Diamond White
    Aug 2012
    Pittsburgh, PA
    659
    Quote Originally Posted by Rbeisaw
    Not sure what tranny the 06's have, but my 03 with the 5spd auto shifts roughly (sorta a clunk, I guess) when I go from reverse into any gear. Asked about this earlier and a bunch of guys I guess have that too, and it runs beautifully otherwise for the most part so I'm not too concerned.
    Not sure about a clicking though! Just thought I'd throw in my experience with mine...
    DavidBoren's Avatar
    DavidBoren is offline Cadillac Owners Enthusiast
    Automobile(s): Volant, VMAX, RX catch can, tranny cooler... RIP
    Jul 2012
    Portland, OR
    31
    518
    Re: Shift to reverse click?
    I have the 5spd auto (5L40E) in my 2005 CTS. I get the same noise. I am under the assumption that it happens more when the car is parked on an incline. With all the weight of the car being held back by whatever it is in a transmission that holds everything at a standstill (I believe I have heard it called the parking pin). Granted that does not explain why it happens when shifting from drive to reverse (which I have also experienced).
    My shift link was broken when I bought the car, there was a ping/tink associated with moving the gear shifter. And there was noticeable play in the shifter (which is really wierd in an auto). I had it replaced and the transmission still thuds from one gear to the next.
    I also have a bad differential bushing, which allows my differential to rock forward and backwards before the torque ever starts turning the wheels... I figure this lurches the car around, thumps the transmission from the back end, pinches my flex disks with ever-changing driveline angles, and I (personally) think it is the number one reason my car makes the noises it does. That is why I am going to have Creative Steel rebuild my driveshaft and replace the transmission mount and differential bushing at the same time. After that, I am going to get my transmission fluid and filter replaced. If that doesnt fix it, then GM designed the cars to make that noise.
  5. #4
    JDodd22 is offline Cadillac Owners Member
    Automobile(s): 2005 CTS 3.6l
    Mar 2012
    St. Louis
    10
    I've had the same noise when the car is parked on an incline/decline. One way to keep the pressure off of the drive shaft and transmission is to use the parking brake before putting the car into park. You won't have the hard clunk or pop when shifting out of park.
  6. #5
    mickmosh's Avatar
    mickmosh is offline Cadillac Owners Member
    Automobile(s): 2010 Camaro SS/RS
    Sep 2008
    florida
    45
    46
    Quote Originally Posted by DavidBoren View Post
    I just noticed that I have about a inch of play in my shifter. It's shifting fine but the play is bugging me.. Never noticed it before guess time for new shifter cable?
  • You may not post replies
