So I just started my car outside and......... $(&* $(&)@(###
Results 1 to 5 of 5
Like Tree2Likes
  • 4 Post By AAIIIC
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, So I just started my car outside and......... $(&* $(&)@(### in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; hey ok as u all know my car wouldnt start the other day figured i was low on gass, anybody ...
    CadillacKid12 is offline Cadillac Owners Connoisseur
    Automobile(s): '04 3.6L, Clear Fogs, 20" TV, Tints, Streeglow, V Bumper
    Oct 2008
    Goshen, CT
    2,501
    figured i was low on gass, anybody know what the problem can be now
    i put 5 gallons in just now and when to start my car, fired up with no problem. yet then started to rev up and down to 1200rpm to 600 rpms and finally shook and just turned off including the dash cluster?
    anybody know what can make my car just shut off after being started. if its not the fuel?
    11sweetteej11 is offline Cadillac Owners Member
    Automobile(s): 2003 cts
    Sep 2012
    1
    Re: So I just started my car outside and......... $(&* $(&)@(###
    I had the same problem with mine only it was shifting really hard. We found out that it was the trans. modular vacuum hose was dry rotted. We replaced it and it's running fine now.
    Oct 2008
    Goshen, CT
    2,501
    Quote Originally Posted by 11sweetteej11 View Post
    mine is idiling hard, i dont have enough time to drive it cuz it shuts down. it just revs up and down and finally shakes and just shuts off
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,224
    Let's start with your other thread, which talked about the same problem - I'm not sure why you didn't just bump that one with an update.
    Quote Originally Posted by CadillacKid12 View Post
    went to get my hair cut today, and car would not start, im on a 1/4 tank of gas yet i know my o2 sensors are shot,
    What do those 2 pieces of information have to do with each other? How do you know your O2 sensors are "shot"? Do you have a CEL? If so, what codes it is throwing?
    anyway thought i was low on gas, last time this happened last year, my friend just came over, pumped the gas a few times and my car started right up,
    today i tried it, no luck, after thinking its my battery this time, i tried to jump it and no luck,
    Why did you think it was the battery? Was the engine turning over when you tried to start it? If the engine turns over, jumping the battery accomplishes nothing.
    so i dumped half a can of starter fluid into it and she fired up fine, only thing is she is...;
    IDLING VERY ROUGH
    Is "...;" intended to be a dramatic pause or something?
    so i pulled it out of the driveway to let it run for a while and i hear a TON OF CLICKING NOISES!!
    Would it not run in the driveway?
    i look inside and it seems my starter is shaking all over the place the pullys are clicking very loudly and i dont want to risk driving it
    Where do you think the starter is located on the engine? I'd be stunned if you could see it, and if it's "shaking all over the place" then it's unlikely it would even start the engine. What pulleys are "clicking"?
    figured i was low on gass, anybody know what the problem can be now[/quote]
    Well, since you haven't told us that you've changed anything or investigated anything since your last thread, I'm guessing the problem is still the same as it was before.
    In other words, adding gas to the fuel tank did not fix the fluctuating idle problem, which is a problem that would not be caused by a low fuel level.
    As suggested in your other thread, and again by 11sweet, you could have a vacuum leak that's allowing unmetered air into the engine and throwing off the ECU's ability to calculate a stable idle. You could have a problem with the idle air control function of the throttle body. There are a variety of things it could be.
    As odthetruth said at the end of your last thread about this same problem, get the car professionally checked. It's unlikely we're going to be able to troubleshoot your car based on your somewhat incomprehensible descriptions.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,157
    Quote Originally Posted by AAIIIC View Post
    KOT
  8. Remove Advertisements
