How to reprogram your TPMS...
Results 1 to 7 of 7
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, How to reprogram your TPMS... in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey folks, I just want to do a DIY to reprogramming your TPMS when you rotate wheels. As you may ...
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,156
    Hey folks, I just want to do a DIY to reprogramming your TPMS when you rotate wheels. As you may know, not all 1st gen CTS' came with it. Even mine didn't, I just gathered the information on how it's done.
    There are two ways, by the book, that this can be done. Both ways requires an air compressor. I advice not to use a foot pump or one of those cheap emergency 12volt pumps.
    You can either let some air out before you start, about 20 seconds worth. So probably several PSI. Or you can let the air out during the process. Please note, when going through the steps you are not add/subtracting air to precise measurements. You are just making the car "see" a pressure difference, so accuracy is NOT needed at programming.
    1. Turn the car to the ON position. Do not start.
    2. Press the Lock and Unlock buttons on the keyless remote for several seconds until horn is heard.
    3. Start at the Driver Front wheel, either remove the air for several seconds and wait for the horn. Or add air if you already taken air out, but don't add if you didn't remove air before hand.
    4. Move on to the Passenger's Front wheel. Repeat step as above, remove/add air until horn sounds.
    5. 3rd wheel would be the Passenger's Rear wheel. Until horn sounds
    6. 4th and final wheel would be the Driver's Rear wheel. Until horn sounds
    7. Cycle power on the car to see the changes. You may not have to cycle power, but it wouldn't hurt. From my understanding, there is a second horn sound after the last wheel. This should be to exiting horn sound, so don't be alarmed.
    You have a set amount of time to do this. So if you hear a random horn sound, it might of exited the programming. If that is the case, you have to start all over from step one.
    Once done, set all wheels to the recommended PSI. Which should be 30psi for our cars, just check your driver's door sill label.
    KOT
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    Re: How to reprogram your TPMS...
    Updated. When letting air out, I'd normally let at most about 3-5 seconds out on each tire and wait on the honk. Honk normally takes a little while so you should be patient with it. I've updated this to FAQ.
    [2006 CTS-V]
    Bolt ons and Bolt ins, and Bolt underneaths.
    Apr 2009
    Ledyard, CT
    37
    9,156
    Thank you sir.
    KOT
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    Good job, Sirs.
    TheBrown57's Avatar
    TheBrown57 is offline Cadillac Owners Fanatic
    Automobile(s): Sold my 03 CTS and went rally car style!
    Feb 2012
    Mason. OH
    27
    457
    Pretty sure mine doesn't have it
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,221
    The Cadillac CTS/CTS-V FAQ page has the procedure, too. As odthetruth said, do not let air out of the tire until the horn honks, as that will release a lot of air unnecessarily. 3-5sec is a good thumbrule, then just stand back and wait for the horn to honk.
    On the non-V cars, does it display the pressures in the instrument cluster, or is that just a V thing?
    Quote Originally Posted by Kingoftypos View Post
    I concur on the foot pump, but why not use one of those 12V pumps? Should work just fine.
    It doesn't need to be that much. I would say a PSI or two is sufficient.
    I don’t understand that second sentence. You can add air for a few seconds just like you can release air for a few seconds. You don’t have to bleed air out beforehand; you can just as easily bleed it out afterwards.
    Yep, the horn will beep twice after the driver’s rear is “seen” by the system.
    Keep in mind that’s the recommended pressure for the factory tires in the factory size for a factory (soft) ride. With all 3 of my cars I’ve found that running the factory recommended pressure makes the car feel soft and unresponsive; running cold pressures in the mid 30s gives sharper steering response and (IMO) feels better.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    Quote Originally Posted by AAIIIC View Post
    I believe that its mentioned in the manual that higher PSI is recommended for high speed driving too.
    [2006 CTS-V]
  10. Remove Advertisements
