Why would a CTS start up and clunk out immediately?
Results 1 to 6 of 6
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Why would a CTS start up and clunk out immediately? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I turn key, it starts up, and then immediately clunks out. I rev pedal while starting it and that gets ...
    StreetsofGold is offline Cadillac Owners Fanatic
    Automobile(s): '03 CTS Base
    May 2012
    102
    I turn key, it starts up, and then immediately clunks out. I rev pedal while starting it and that gets it to run. This happened many times in one day... and hasn't happened since.
    Any ideas?
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    Re: Why would a CTS start up and clunk out immediately?
    low voltage.
    try to start it without hitting the gas, i bet she wont turn over then the clock spins possible backwards.
    May 2012
    102
    When I wouldn't hit the gas it would turn over and start, but then immediately clunk out. The volts read OK on the radio. I think possibly something to do with the fuel cause the gauge was reading inacurrate a month ago, it was slightly under 1/4 tank so maybe I ran out of gas. It starts fine now though so I just can't figure it out.
    Jim's 06 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2006
    194
    Check the hard plastic tubing from the air filter housing to the intake plenum. Make sure all joints are tight and there are no gaps between the different pieces, especially on the bottom side where you can't see them. I had the same start/no run problem after changing an air filter, and it turned out to be a gap in the intake air plumbing.
    74chvy glasshouse is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS 3.6 , 74 chevy caprice
    Jan 2012
    California, desert empire
    395
    On my Honda its a relay under dash something in relay gets stuck I tap the relay and starts up
    ztollon's Avatar
    ztollon is offline Cadillac Owners Enthusiast
    Aug 2012
    629
    How many miles are on the vehical? Try replacing the fuel filter.
  9. Remove Advertisements
