drive shaft u-joint
Results 1 to 14 of 14
Like Tree2Likes
  • 4 Post By Lzr
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, drive shaft u-joint in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; HI I'm a newbie to the forum and to my cadillac cts 04. I've got a few issues with it. ...
    griffint007 is offline Cadillac Owners Member
    Automobile(s): 2004 cts
    Aug 2012
    37
    6
    drive shaft u-joint
    HI I'm a newbie to the forum and to my cadillac cts 04. I've got a few issues with it. It has 84000 miles and it appears i have the "parade clunk". My local mechanic told me he thinks its the u joint. Is the u joint replaceable or do i need a whole new drive shaft? Also where can i find these parts my mechanic could not find one? Thank you in advance. I'd just like to know before i go to a dealer and get bent over. I just got this car.
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    Re: drive shaft u-joint
    search drive shaft flex disk or gumbo
    there is no u joint on it.
    Lzr
    Lzr is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS - 3.6L, perf pkg, RX catch can, Vmax Ice, Volant CAI
    Oct 2011
    Montreal, Qc
    353
    Quote Originally Posted by ghettomike View Post
    i think you meant guibo
    gumbo sounds like soup to me
    also correct me if i'm wrong but if your gonna replace those, make sure you also replace the worn out parts that cause the flex disc to break in the 1st place (newyorktrini comes to mind here)
    ghettomike's Avatar
    Apr 2008
    off the grid.
    33
    7,872
    Quote Originally Posted by Lzr View Post
    when they break your transmission feels like soup lol
    Lzr
    Oct 2011
    Montreal, Qc
    353
    hehe i'll take your word on that one, i hope mine stays in the can for a long time
    Aug 2012
    37
    6
    I looked under my car today and there is a u-joint in the middle of the shaft. When I was under the car I pushed up on the rear differential and I noticed a lot of play there. The bushing appears to be worn out. How much of a job is it to change this bushing and where can I get one?
    ghettomike's Avatar
    Apr 2008
    off the grid.
    33
    7,872
    someone correct me if im wrong..but the center of the driveshaft is another bushing with a carrier berring i think??? or something like that.
    i havent looked under her skirt in a while but i thought there were no u joints??
    the flex disk is the most common driveshaft issue. and from where im sitting i would GUESS that is your issue.
    look up creative steel. you will have to shim your transmission if you get vibrations from the new disks as the tranny mounts wear out as well and the poly bushings have tighter tolerances that the oem rubber.
    revshift makes a different version of it. both companies sponsor the site, ive only dealt with creative steel and they are great guys.
    Lzr
    Oct 2011
    Montreal, Qc
    353
    as far as i know your right, was under there today, and looked at both flex disc and what i could make out of the carrier bearing, but did not see any u joint, not saying there isn't one, but i didn't see it
    i had a knock 1 time yesterday when putting it in reverse from park, and been quite paranoid and had to check it out today, have no idea what happened, and she has been running like a champ since
    Jim's 06 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2006
    193
    voodoochikin04 is offline Banned
    Automobile(s): 2003 cts, 2004 Cts-v
    Nov 2012
    Norfolk, NE (eastern Nebraska)
    31
    316
    there is a carrier bearing in the middle of the 2piece driveshaft. AND there is a standard looking u-joint there connecting the front and rear driveshafts. The front driveshaft also contains a slip yoke, which is pulled apart to remove/install the carried bearing. I have verified this info tonite on my 2003 cts.
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    Quote Originally Posted by voodoochikin04
    Carrier bearing is in the rear differential. It's called a center support bearing.
    Nov 2012
    31
    316
    Also called a carrier bearing and typically easier found when searching for drive shaft carrier bearing, than drive shaft center support bearing. Also called carrier bearing when referenced to the exact same part on most larger trucks with two piece drvieshafts.
    jran0823's Avatar
    Apr 2011
    GB, WI
    30
    1,017
    Anytime I ask for a carrier bearing I get parts for the rear diff at my shop. Anyone else in the field calls it a center support including parts suppliers.
  16. #14
    quaver's Avatar
    quaver is offline Cadillac Owners Member
    Automobile(s): 2006 CTS
    Feb 2013
    14
  17. Remove Advertisements
