Downshift problem from 5th to 4tg - Manual 5sp Transmission - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Like Tree1Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Downshift problem from 5th to 4tg - Manual 5sp Transmission in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; So, news from the service garage, the transmission itself is ok, the problem is elsewhere, the part in the red ...
  1. #16
    chlapec10 is offline Cadillac Owners Member
    Automobile(s): CTS 2006 2.6L M5
    Aug 2012
    Slovakia (Europe)
    29
    73
    Re: Downshift problem from 5th to 4tg - Manual 5sp Transmission
    So, news from the service garage, the transmission itself is ok, the problem is elsewhere, the part in the red box is is worn out, honestly don't know how it's called in english (would be glad if some tells me)
    and here comes the problem, the parts needed are apparently not sold anymore i need part 25746745 and 25740954... any tips?
    Thank you
  2. #17
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,304
    Quote Originally Posted by chlapec10 View Post
    I would call the metal rods "shifter linkages", but I don't know what the official name is. I'm assuming there are bushings, rubber or hard plastic, that are in the ends of the linkages, and that the bushings have worn out.
    Thank you
    Attachment 98020
    25746745 is the shift lever itself. I don't understand how that could be worn out. When my brother's CTS-V had excessive play in the shifter and became very notchy, I thought maybe the plastic ball that is in the middle of the shift lever had gotten worn out. It turned out that it was fine, and it was the linkage bushings that were destroyed and allowing the shift lever to move around more than it should. In other words, I doubt there's anything wrong with that 2576745 part - I think fixing the linkage bushings will firm up the shifter so it goes into gear properly.
    From that diagram it looks like it might be the same shift lever as the CTS-V shift lever (just with different parts bolted to the bottom of it). Maybe you could look into
    I did find this '03 shift lever assembly on eBay for $70. Their ad says no international shipping; if you can't find something similar over in your neck of the woods, I would be willing to take delivery of the part and then ship it to you.
    As for 25740954, that shifter assembly on eBay appears to include those parts. However, it's used, so the bushings may not be in the best condition. I would guess that those bushings were never available separately from the factory - you would have had to replace the whole linkage assembly (which, as you found, is no longer available). I (and others) had a similar experience with a shifter joint on my Subaru. The stock bushings would wear out, and there was no factory replacement parts. What someone figured out was that McMaster-Carr makes all sorts of universal bushings in a variety of dimensions and materials. It's just a matter of measuring the diameter of those pins that go through the shifter linkages, removing the old, worn out bushings from the linkages, measuring the outer diameter of the holes in the linkages, and then finding bushings that will fit in their place.
    In the case of the Subaru, the stock bushings appeared to be a soft urethane, and we all replaced them with a harder nylon bushing. Worked out great, and made the shifter feel way better. This post gives an idea of what I'm talking about - the nylon McMaster bushings (bottom center of his first picture) went into the part at the bottom left of his first picture. Obviously, it's not the same type of shifter setup as on your CTS, but hopefully that gives you an idea of how you could swap out the bushings in your existing shifter linkages. It should be a very inexpensive but effective fix.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  3. #18
    Aug 2012
    Slovakia (Europe)
    29
    73
    Sorry, I messed the diagram a litlle
    What I was told that 25746745 is the whole set, both parts 4 and 5(shifter + linkages)..
    and 25740954 are the rods, number 3 on the diagram, these would be needed as well, but are also discontinued.
    The red box is the location where the trouble is...
    Thanks for the ebay link as well as your offer for help, I will check both ebay and McMaster-Carr and see what's going on.
    Given the situation I was already thinking of having the rods/screws and bushings made to order here...
  5. #19
    Aug 2012
    Slovakia (Europe)
    29
    73
    double post
  6. #20
    AAIIIC's Avatar
    Aug 2007
    6,304
    Yeah, I'm guessing that will be your best solution.
  7. #21
    Aug 2012
    Slovakia (Europe)
    29
    73
    Well, to add the solution...
    It turned out it was the synchro ring that needed to be changed.... that turned out to be even a larger problem to get hold of...
    I later found out that only ONE seller in the united states (no other in the whole world) sells spare parts for the 5 sp manual tranny...
  8. #22
    AAIIIC's Avatar
    Aug 2007
    6,304
    Nevermind, wrong thread!
  9. Remove Advertisements
