Turn signal gremlins
Results 1 to 11 of 11
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Turn signal gremlins in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; My left hand turn signal works sometimes or just doesnt work.....of course when i go to get it check out ...
    07lubbockcaddy is offline Cadillac Owners Member
    Automobile(s): 2007 cadillac cts
    Aug 2012
    44
    1
    My left hand turn signal works sometimes or just doesnt work.....of course when i go to get it check out every thing works... no later than an hour later it stop working again I have check the bulbs they are all good I have checked the fuses they are all good. even tried the hazzard light and the left side wont blink and than it will starts working....I love my car and I understand there will be small problems.
    Can any one help me!!!
    Chris G
    simple2me's Avatar
    simple2me is offline Cadillac Owners Fanatic
    Automobile(s): Black 06/08 Satillac CTS-O
    Nov 2011
    Southwest Louisiana
    398
    Re: Turn signal grimlins!!
    could be in the steering column. I haven't pulled apart mine but generally everything goes through the turn signal cancellation switch. These cars have different circuits for the brake lamp and turn signal lamps so I don't imagine the brake circuit goes through the turn signal switch.
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    Quote Originally Posted by 07lubbockcaddy View Post
    Chris G
    Might need to replace the signal stalk. Whenever I would turn to the left on my V, the highbeams would cut on. LOL I ended up replacing the stalk... no issues for a few months now. Rippy has a good price on em. I picked mine up from him for somewhere around ~50 or less if I'm not mistaken. Then again... V stalk <> CTS auto stalk.
    [2006 CTS-V]
    Bolt ons and Bolt ins, and Bolt underneaths.
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,256
    Honestly fellas, I don't think it's the turn signal stalk. Because I am looking at the schematic and with the problem at hand. Where the "left turn" as well as the "hazard lights" on the left side doesn't work. I am point towards either to a grounding issue, which is common with GM cars specially with the front turn signals. Or the turn signal module that is located next to the steering wheel.
    I say this, because the hazard switch that is above the radio goes directly to the turn signal module. From there it goes to the lights.
    KOT
    arogers260's Avatar
    arogers260 is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Luxury/Sport package
    Mar 2012
    Indiana
    722
    I been having a problem with my front left turn signal burning the plastic onto the contact. For some reason it's getting way to hot.
    pbruno's Avatar
    pbruno is offline Cadillac Owners Member
    Automobile(s): CTS 2007
    Jul 2013
    3
    Re: Turn signal gremlins
    Did you end up fixing the issue? What was the problem?
    aviatordave is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS, 1976 Seville (sold)
    Apr 2013
    San Antonio
    68
    143
    Quote Originally Posted by pbruno View Post
    doubt you'll get an answer.... this post, last year, was his one and only post.
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    It could be the bulb holder, if you think about it if that's making contact, you go over a bump, the circuit breaks and so on.
    pbruno's Avatar
    Jul 2013
    3
    I didn't think I'd get a reply.. but gave it a shot..
    @CTSUK would the bulb holder issue affect both front and back lights as well as the arrow on the dashboard? In any case. I'm going to get it checked, don't think I'll be figuring this one out and it's a bit dangerous driving around with a defective turn signal..
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,055
    More than likely a bad turn signal stalk on your column if your blinkers are going all crazy on you....
    DeFo is offline Cadillac Owners Fanatic
    Apr 2011
    158
    I had the same problem a while back.....and it turned out to be the bulb......the filament inside broke and the coil would sometimes be "resting" on the post, allowing the bulb to work, and at other times, it would not work.
    I changed the bulb, and the problem has not resurfaced in over a year.
  14. Remove Advertisements
