PVC Fresh air intake tube delete
Results 1 to 4 of 4
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, PVC Fresh air intake tube delete in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey guys im planning to delete the driver side fresh air tube on my 05 3.6 and add a oil ...
    Stuff_buster is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS 3.6
    Feb 2012
    29
    100
    Hey guys im planning to delete the driver side fresh air tube on my 05 3.6 and add a oil fill cap breather kit. Has anybody else done the same? I just want to be fully informed before i do so.
    Feb 2012
    29
    100
    Re: PVC Fresh air intake tube delete
    bump...anybody run a valve cover breather
    tormented is offline Cadillac Owners Member
    Automobile(s): 2004 SRX V6 RW
    Nov 2010
    76
    Well first of all, it's PCV (positive crankcase ventilation), not PVC, (poly vinyl chloride ) plastic pipe.
    I tried the breather, via a lawn mower air filter, for a while but the wife complained of that awfull smell in the garage after the engine was shut off. I went with a modified catch can instead and am very satisfied with that. Throttle body stays a lot cleaner and no oil in the intake tube and no more stinky fumes which could sometimes be smelled in the car at stop lights etc when I had the open to the air breather on the valve cover.
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    If installing a breather and deleting the fresh air tube. make sure the barbs are capped and if you use an open breather you will have excess unmetered air entering throwing the fuel trims off and the fumes venting. The RX breather has a oneway checkvalve integrated into it that only allows fresh air in and no vapors out and it also controls the amount of air entering so that it is only an amount the PCM can adapt to with acceptable parameters.
    If you need instructions, give me your email & I'll send them.
  7. Remove Advertisements
