ticking noise above 60mph .purge valve?
Results 1 to 5 of 5
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, ticking noise above 60mph .purge valve? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; when i go on the freeway or go over 60mph istart hearing a ticking noise that seems to be coming ...
    74chvy glasshouse is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS 3.6 , 74 chevy caprice
    Jan 2012
    California, desert empire
    395
    when i go on the freeway or go over 60mph istart hearing a ticking noise that seems to be coming from passenger front of car it doent get louder once im at 60 it stays the same at any speed . when i get home pop hood nothing step on gas to raise rpms nothing. could it be bearings , purge valve , brakes , suspension??
    any ideas , anyone experience this ???
    thanks
    Firewalker is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS 3.6l
    Jan 2012
    Beavercreek, Ohio
    185
    Re: ticking noise above 60mph .purge valve?
    It probably is not the purge valve, as the ticking noise associated with that is hard to discern while driving. To rule out the purge valve, start the car, raise the hood, go to the passenger side of the engine compartment, pull off the engine cover and reach down and touch the purge valve. You can physically feel the ticking. If you feel it, replace it. I think I paid $30 and the total job took less than 5 minutes. I also doubt it is bearings, as they typically present themselves during turning at slow speeds. I hate hearing noises in my car as well, I want a quiet ride, so I get your frustration. Unfortunately, a lot of it is trial and error. Rule them out one by one until you find the culprit! The upside is that what you are describing does not sound like an expensive fix.
    Good Luck
    Jeff
    Jan 2012
    395
    Maybe heatsheild? Ill try ahd have my wige take a vid while driving hopefullyu can hear over wind
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    It's been mentioned on here that sometimes the valve in the oil filter cover can make a ticking sound.
    I think they are easy to replace or just change the whole cover.
    Jan 2012
    395
    just replaced that. does it sound likesomething bad since it only does it over 60mph? i think i m gonna take off bumper cause i recently put in hids
    thanks
  8. Remove Advertisements
