Blacked Out HeadLights
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Like Tree3Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Blacked Out HeadLights in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey pals, recently used VHT Night Shades to black out my tails and it turned out great. Now wanting to ...
    Mr Nix's Avatar
    Mr Nix is offline Cadillac Owners Member
    Jul 2012
    31
    Hey pals, recently used VHT Night Shades to black out my tails and it turned out great. Now wanting to do my headlights. Slightly nervous about functionality of headlights afterwards. Has anyone every done this? Suggestions?
    Thanks, Mr Nix
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,039
    Slightly? Don't do it, well, if you only drive during the day, go ahead I guess...
    Mr Nix's Avatar
    Jul 2012
    31
    Ever seen it done?
    Fiero is offline Cadillac Owners Member
    Automobile(s): 2007 CTS 3.6L Performance / Appearance 18" rims
    Dec 2010
    Toronto, Ontario, Canada
    48
    Re: Blacked Out HeadLights
    I ordered Xpel Headlight protection in "dark smoke" colour. Its thick vinyl that is applied with solution and squeegee.
    I haven't applied them yet - I just got a set of aftermarket dual-halo headlights so I might put them on the new ones.
    Anyway, this is just one option....
    http://www.xpel.com/products/headlight_protection.asp
    jamesdeann is offline Cadillac Owners Member
    Automobile(s): 03 cts
    Jul 2012
    36
    6
    I've done them before, you take any type of automotive clear coat, ppg, chroma clear, etc. Add catalyst, and reducer. Then add black base to it, your going to want to add a little at a time. Make sure you have a piece of lexan for a test peice. Wet sand your headlights with 600 to 800 grit. And wash off residue with soap and water. Next wipe off with wax and grease remover, and spray. Remember even coats because the tinted clear is like a candy coat. The more you spray, the darker it will get. So i would do both headlights between coats. then finish off with a coat of clear non tinted to seal. Fifteen minutes after. Because you will need to wetsand and buff. You don't want to rub off the tint with a buffer. Two coats of clear should prevent this. Unless your a bad ass painter. Then no buffing necessary. Hope this helps.
    Mr Nix's Avatar
    Jul 2012
    31
    Quote Originally Posted by jamesdeann
    Was your visibility decreased much?
    Mr Nix's Avatar
    Jul 2012
    31
    Quote Originally Posted by Fiero
    Where'd you get the dual halos?
    Dec 2010
    48
    just do a search on Ebay. They are manufactured by eagle eye (china?) but lots of distributors online.
    If you search the forums here you will see some pictures.
    Dec 2010
    48
    Quote Originally Posted by Mr Nix View Post
    +1 This might be the best way to go - sounds easy to f-up tho.... What happed to your visibility using this method?
    Mr Nix's Avatar
    Jul 2012
    31
    Those look good man. For sure
    Jul 2012
    36
    6
    I usually do a smoke tint. It looks good and Visibility isn't too bad with hids. I would go with the vinyl, because once your lights are painted. There's no fixing. At least you can remove the vinyl if needed.
    Mr Nix's Avatar
    Jul 2012
    31
    Thank for advice. Very useful
    SHORTSTACK's Avatar
    SHORTSTACK is offline Cadillac Owners Connoisseur
    Automobile(s): 07 CTS 3.6
    Nov 2010
    York, South Carolina
    38
    1,484
    Im all for murdering out a vehicle. But the headlights is something i wouldn't consider due to the FACT that you will significantly lose light output. But there is a way around that, you can upgrade to a 55w or 100w hid kit. Be careful of the 100w, the mother fukker is like shining a bright ass spotlight in your eye. I have 100w hid kit for my cars high beams, they are very bright...
  16. #14
    hey8you's Avatar
    hey8you is offline Cadillac Owners Fanatic
    Automobile(s): 2014 Dodge Charger R/T, 2005 CTS, Gone, given to dad!
    Aug 2009
    Roseville, Ca
    38
    329
    I did mine with a light coat of VHT Night Shades and solved the problem with dim lights with 55w HIDs. If I knew about the vinyl, I would have used that.
  17. #15
    Mr Nix's Avatar
    Jul 2012
    31
    Quote Originally Posted by hey8you
    Exactly what I was looking for.. Did you go 6k or 8k?
  18. Remove Advertisements
