Results 1 to 14 of 14
Thread: Need new wheel bearing. please help
    roma604 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac CTS 3.6L
    May 2008
    Vancouver, BC
    29
    191
    So my abs/traction lights have been acting up lately.. took it to the stealership and they said my front right wheel bearing needs to be replaced. they said when they replace the bearings, 90% of the time the harness needs to be replaced too.. is this true??!?
    ..also my coolant was running low so i asked them to do pressure test and sure enough my water pump is leaking.. sooo they wanted to fix everything for a grand total of $1431.46........ LOL.. so i walked out with the list of things i needed.
    Wheel bearing: #12413071
    Wheel speed harness: #10340314
    Water Pump: #12645176
    soo i did some digging on the forums and been reading that a lot of people are changing both the right and left wheel bearings at the same time.. is this really necessary?? i found all my parts on rockauto.com and i really want to order today so i can get everything fixed before more damage is done as this car is my daily driver.. please and thank-you for any help
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    Re: Need new wheel bearing. please help
    Always best to replace in pairs, if you replace one you put stress on the older component causing it to fail more rapidly so replace in pairs
    I guess there is some logic behind the harness, probably just in-case its that rather than the bearing and part of the course, if its not to expensive may as well get one, one more new part for the car.
    for around $700 you could replace most of that saving $731 labour costs lol
    May 2008
    Vancouver, BC
    29
    191
    Thanks for the response CTSUK, i am going to go ahead and do both... i did a lot of reading and found that it is best that i just go ahead and change both bearings. then i shopped around and read all my different options for parts and came up with this..
    Bought acdelco water pump and 2 acdelco harness's off rock auto for $286
    2 'Timken' Front Wheel Bearing and Hub Assembly's off ebay for $320
    Saved so much money going this route.
  5. #4
    Bluehaze07's Avatar
    Bluehaze07 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS
    Apr 2009
    Honolulu, HI
    1,395
    Quote Originally Posted by roma604
    I have a question. Doesn't the wheel hub assembly come with the abs harness?
  6. #5
    CTSUK's Avatar
    May 2012
    United Kingdom
    35
    717
    no they don't, its separate to the hub, can always try it without swapping it and then if its an issue order the harness.
  7. #6
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    Quote Originally Posted by Bluehaze07 View Post
    It does come with the short wheel harness, I assumed they were talking about the chassis harness.
    I didn't know they were prone to failure, never had to replace one.
  8. #7
    74chvy glasshouse is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS 3.6 , 74 chevy caprice
    Jan 2012
    California, desert empire
    395
    Sothe abs tractionlite acting up is a sign of baf wheelbearings
  9. #8
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    Quote Originally Posted by 74chvy glasshouse
    ABS and the TC isn't a sign of just a bad wheel bearing. The ABS and TC light are triggered when everything isn't meeting the given perameters of the EBCM for the ABS system to work properly.
  10. #9
    May 2008
    Vancouver, BC
    29
    191
    ya it was more than just my bearing.. they scanned my car and got the following codes: C0253/C0221/C0040/C0041/C0042
    no idea what any of them mean... but this is what it says here on the sheet. 'tech finds RF sensor not registering at low speeds(sensor) and dropping out on turns(harness). Steering not centered code stored in history - performed re-centering procedure - code cleared.'
    anyways all my parts are in transit right now, i'll update once i get them installed.
    edit: just found this site with all the codes http://www.southwestcadillac.com/?p=13
  11. #10
    Argent1's Avatar
    Nov 2010
    2,937
    roma, isn't this the car that was stolen awhile ago ?
    If so, is it possible to get your insurance to cover this as collateral damage from that ?
    If not please disregard.
  12. #11
    Firewalker is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS 3.6l
    Jan 2012
    Beavercreek, Ohio
    185
    Are you planning on doing the install yourself? If so...it would be a great time for someone "cough" to do a "how to change your water pump tutorial!" haha
  13. #12
    May 2008
    Vancouver, BC
    29
    191
    yes it is.. i tried to get them to do it but they wouldn't... said my car is 5 years old and the bearings/water pump are things that go bad, i was not happy but oh well, cant do anything now........
    Quote Originally Posted by Argent1 View Post
  14. #13
    May 2008
    Vancouver, BC
    29
    191
    Sorry, im getting my dad's friend who is a mechanic to do it.. i don't have the proper tools or the know-how to do the bearings or water pump lol.. droppin my car off on friday at his house before work.. all my stuff from rockauto came yesterday so i'll have the water pump fixed first.. just waiting on my wheel bearings from ebay to come.. hopefully they get here by friday so i could get everything done.
    Quote Originally Posted by Firewalker View Post
  15. #14
    jmtz is offline Cadillac Owners Member
    Jan 2014
    4
    Hey roma how much did you get charged for the code readings. Or was it covered under ur warranty
    Hey there I hope you can help me I have that problems where my ABC and TC kick in every day. Sometimes the breaks get hard and it takes between 1 and 2 seconds before a complete stop. I Could never get any codes Now I've noticed that when I start the car and I turn the steering wheel to one side and back( with the car still on parking) the ABS/TC kick in and once threyre on I dont have to deal with that until next time I turn the car on. I was about to buy the front wheel hub to try that on both sides in case it was the wheel speed sensor causing the trouble. But then I saw something about the steering position sensor posted. Any ideas??
  • You may not post replies
