06 Cadillac cts misfire
Results 1 to 9 of 9
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 06 Cadillac cts misfire in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I have a 2006 Cadillac cts that has had codes for a misfire on all 6 cylinders. Before I digg ...
    smullins230 is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac CTS
    Jul 2012
    3
    I have a 2006 Cadillac cts that has had codes for a misfire on all 6 cylinders. Before I digg any deeper into, what might be causing the misfire?
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,055
    Plugs and coil packs are a good start...
    All 6 leads me more towards a timing issue though.
    Lilmistersmom is offline Cadillac Owners Member
    Automobile(s): 2006 CTS 3.6L
    Jan 2013
    39
    1
    Re: 06 Cadillac cts misfire
    I am having the same problem.. Codes came back as misfires for all 6 cylinders... Did you replace the plugs and coils or was it the timing chain? Or was it something else?
    ztollon's Avatar
    ztollon is offline Cadillac Owners Enthusiast
    Aug 2012
    629
    Had this problem a week ago. Posted about it and got sarcasm back.. my engine cover retained moisture and messed w my electronics. I cleared the codes and removed my engine cover.
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    On my car the coils are under the intake plenum. The engine cover foam comes no where near them, and I thought the foam was the closed cell type that won't absorb or hold moisture.
    ztollon's Avatar
    Aug 2012
    629
    If u have a 3.6 like the rest of us yes its very close. Coils are almost accessible without taking off the upper intake plenum and you evgine covers around the top outside of tour engine. And if the foams closed cell why does it retain oil or soot or get dirty at all. Get off you high horse homie ur shit smells just as bad as mine. I dought the biggest cadillac dealership in michigan woyld have a bunch of dipshits working there. If u think all six coils and plugs are bad ur silly. If the Ecu was bad ur shit would barly run. Leaves it down to electrical considering you have your services done on time. What messes w electical more than moisture and dirt. At the very least disconnect all your sensors and coils and clean them. W any luck it could be a loose connection
    CTS.mommy is offline Cadillac Owners Member
    Automobile(s): 2006 CTS 2.8
    Feb 2013
    Nanaimo, BC, Canada
    29
    3
    Had the same problem only a misfire on 3 cylinders on my 2.8L, only getting 25lbs of compression out of the engine and mechanic recommends rebuild/replace engine due to known Cadillac Timing Chain issue (jumped and then bent the valves).
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,697
    Are you still experiencing concerns, CTS.mommy? If so, then I encourage you to contact the helpful GM of Canada team for further assistance. In case you weren't already aware, their contact information is available at http://www.gm.ca/gm/english/corporat...actus/overview.
    Best,
    Katie
    Submariner409's Avatar
    Submariner409 is online now If it won't run, install a boombox
    Feb 2006
    MD Eastern Shore, Kent Island
    56,554
    CTS.mommy, Please do NOT "Report Post" for no reason. Use the correct tabs on your computer or smart phone. Your two posts were sent to Admin team for moderation - if you needed to resurrect this dead thread, you could simply post to it.
    Please read the CF Rules and Guidelines up in the Registration and Site news forums.
    Thanks for your interest. CF Staff.
  12. Remove Advertisements
