Drove thru water help
Results 1 to 9 of 9
Like Tree5Likes
  • 2 Post By A48WillyzGuy
  • 2 Post By odthetruth
  • 2 Post By Argent1
  • 2 Post By ghettomike
  • 2 Post By Argent1
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Drove thru water help in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Ok it was raining today, I was driving home and road started to fill with water just over the curb, ...
    Heather512 is offline Cadillac Owners Member
    Automobile(s): 2003 cts
    Jul 2012
    32
    1
    UnhappyDrove thru water help
    Ok it was raining today, I was driving home and road started to fill with water just over the curb, started to pull over and car said low oil pressure stop motor!! I did and had the car towed home. I'm very worried, can anyone help ease me... The car still hours later still says the same thing
    SHORTSTACK's Avatar
    SHORTSTACK is offline Cadillac Owners Connoisseur
    Automobile(s): 07 CTS 3.6
    Nov 2010
    York, South Carolina
    38
    1,484
    Re: Drove thru water help
    You might have had water get on some electrical connectors. Try and get under the car to see what could have got wet. Take them apart and clean them with electrical contact cleaner. Do the same for the top of the engine compartment, look and see if any electrical got wet. Disconnect the battery, then re-connect it. See if that deletes the error message. My wife had a bad rain storm at work last friday, there was 8"+ of standing water, she drove through it just fine. With no problems...
    A48WillyzGuy's Avatar
    A48WillyzGuy is offline Cadillac Owners Fanatic
    Automobile(s): 2003 CTS
    Mar 2011
    Evansville, IN
    29
    294
    First thing to check would be the oil. If that is at the proper level, and not milky then look into sensors and whatnot.
    If its excessively dark, milky, low or if the engine makes ticking/knocking noises then it's likely got nothing to do with the electrical system lol.
    ghettomike and ghettomike like this.
    SHORTSTACK's Avatar
    Nov 2010
    38
    1,484
    Quote Originally Posted by A48WillyzGuy View Post
    Could be either or... I seriously doubt she blew the motor or cracked the block by driving through water! But who knows. Anything is possible. But yes, common sense would be to check the oil and raditor, guess i was assuming it was done.
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    Did you have your under engine splash guard in place? Is it missing? Just trying to get an idea of how much water got where.
    SHORTSTACK and SHORTSTACK like this.
    [2006 CTS-V]
    Bolt ons and Bolt ins, and Bolt underneaths.
    SHORTSTACK's Avatar
    Nov 2010
    38
    1,484
    Good question, i didnt think about that...
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    This could be another case of misinterpretting the real function of the OLM.
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    there is a oil pressure sensor on the front of the engine. it works based off it being given a signal of low pressure, not it cutting the signal out.
    this means if you unplug the sensor you will not have the warning.
    if you receive this message you either have a bad sensor, or low oil pressure.
    change out the sensor...still have the warning do a compression test.
    Kingoftypos and Kingoftypos like this.
    Argent1's Avatar
    Nov 2010
    2,937
    We still don't know if the OP actually checked the oil yet. Or ever.
  12. Remove Advertisements
