instrument cluster malfunction
Results 1 to 8 of 8
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, instrument cluster malfunction in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; My 03 CTS cluster stopped working on me last night. It is stuck at 2,000rpm, 35mph, and a quarter tank ...
    jeff0101 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac cts luxury sport, with slotted rotors
    Feb 2010
    Fredericksburg, Virginia, Unit
    24
    203
    My 03 CTS cluster stopped working on me last night. It is stuck at 2,000rpm, 35mph, and a quarter tank of gas. Also it doesn't light up anymore. The only thing that lights up is left, right, and hazard turn signals. Also the red gear selector light isn't on. I tried the easy route and disconnected the battery and checked my fuses and nothing happened. Anyone have any idea whats going on.
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    Re: instrument cluster malfunction
    First thing I would try is disassembling around the cluster to remove it and check for any connectors popping off then work back from there, you might find a loose connection and then when you put it back in place it works again, depends how its plugged in at the back.
    josney's Avatar
    josney is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS
    Dec 2006
    South Carolina
    50
    2,299
    huh, never heard of anyone having trouble like that. i have the old cluster from my 03 (with the stupid ass clock) sitting in the garage. let me know if you need it.
    Feb 2010
    24
    203
    My main question, is there another power supply for the cluster? Like a capacitor or something of that nature. And are there any special fuses that I might have missed?
    josney's Avatar
    Dec 2006
    South Carolina
    50
    2,299
    KOT should be able to help with something like that. i am sure he will be lurking around at some point. maybe he can shed so light.
    CTSUK's Avatar
    May 2012
    United Kingdom
    35
    717
    Check the fuses under the hood one is labeled ELEC PRNDL, also worth checking any other fuses in that block.
    Have you checked fuses also in both rear under seat blocks both left and right?, if not check them all one at a time.
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,216
    And there are more in the fuse boxes under the rear seat.
    I've read this a couple times but kept on having the brain fart of the century. I have seen this problem before, so I thought, but I couldn't figure out what the fix was.
    With the previous problems with the IC, for some it was the connection on the back. While for other's it was the IC itself, or either they couldn't figure it the connection out. Some who could, said there was a cold-solder joint on the board for the IC, hence the connection. So if you are able to solder, then I suggest removing the IC and re-solder the solder joints.
    Check out ghettomike's DIY to remove the IC...
    http://www.cadillacforums.com/forums...r-removal.html
    KOT
    Feb 2010
    24
    203
    Im going to give it a try and check each fuse, then if I can't find anything I will pull out the cluster
  11. Remove Advertisements
