03 cts trouble codes
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 03 cts trouble codes in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Have an 03 cts that is throwing p0171,300,301,302,303,305 codes. I have replaced Maf sensor due to having p171,174 the past ...
    arogers260's Avatar
    arogers260 is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Luxury/Sport package
    Mar 2012
    Indiana
    722
    Have an 03 cts that is throwing p0171,300,301,302,303,305 codes. I have replaced Maf sensor due to having p171,174 the past month off and on now just getting 171. The Maf sensor has been replaced twice this past month thinking I had a defective one, had smoke test, and fuel pressure test done too. None seem to be the problem and no shop can find a problem so they say. Just got the misfire codes today can someone help me out I'm getting frustrated at this problem.
    san2cci's Avatar
    san2cci is offline Cadillac Owners Fanatic
    Automobile(s): 05 3.6 CTS, Volant, V Exhaust, Hotchkis (SOLD!); 2010 2SS
    Dec 2011
    Camden County, NJ
    28
    410
    Re: 03 cts trouble codes
    Powertrain - Fuel and Air Metering - ISO/SAE Controlled
    Fuel Trim System Lean Conditions
    Bank 1
    No PCM codes set, ECT input from 176-230°F, engine speed 1000-4000 rpm (0-4000 rpm on VIN 1), throttle angle steady below 91%, VSS under 70 mph, purge duty cycle below 80%, then the PCM detected that the LONGFT was over 100, or that the SHRTFT was below 94, either condition met for over 25 seconds
    san2cci's Avatar
    Dec 2011
    Camden County, NJ
    28
    410
    That's all I can find on P0171
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    I honestly think I'm having ECM PCM problems cause the system riding lean keeps showing up after new Maf sensor on and the vehicle passed both smoke test and fuel pressure test as being correct.
    san2cci's Avatar
    Dec 2011
    Camden County, NJ
    28
    410
    When I had a Fuel Trim System Lean Conditions on bank 2, it was because I had a hole in my exhaust right by my resinator...but I doubt that's your problem. Have you brought the car to a GM dealer?
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    Basically this means that an oxygen sensor in bank 1 has detected a lean condition (too much oxygen in the exhaust).
    Bank 1 is the side of the engine that has cylinder #1. The P0171 is one of the more common trouble codes.
    This code is triggered by the first downstream (front) O2 sensor. The sensor provides a reading of the air:fuel ratio leaving the engine's cylinders, and the vehicles powertrain/engine control module (PCM/ECM) uses that reading and adjusts to keep the engine running at that optimum ratio of 14.7:1. If something is not right and the PCM cannot maintain the 14.7:1 ratio, but rather there is too much air, it triggers this code.
    More can be read here:
    http://www.obd-codes.com/p0171
    Worth checking your air filter if you haven't already
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    I just put brand new air filter on new Maf sensor had fuel injectors cleaned and throttle body. Haven't made it to my local Cadillac the light just came back on today and they r closed on weekends. My main concern right now is to y I'm having 5/6 cylinders misfiring with the p0300-305 the only one not present is p304. I spoke with a Cadillac dealer technician about the p0171 code and what I've done and he said its highly possible that my throttle body wiring is bad. But that's just an assumption based off the info given over the phone. The misfire codes just showed up today but it seems to run just fine no hesitation, lag in acceleration none of that just codes
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    update....i disconnected my battery and since reconnecting so far no CEL but we shall see if it decides to come back up and which codes i get this time.
    Calvin_Z is offline Cadillac Owners Member
    Automobile(s): CTS
    Nov 2011
    16
    Did that solve your problem?
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    No it didn't unfortunately I still have p0171 and p0174. The misfire codes went away after I put new spark plugs in.
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    I plan to do the Pcv upgrade and new valve cover due to to oil leaking into the spark plug wells but won't have time for a week or so.
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    So I recently found that my air box wasn't put back together right by a local shop that did my smoke test. The bottom wasn't sealed so that could be part of my problem and also coming to the dealership I was told that the oil leaking into my spark plug well could cause me to be riding lean on one of my banks not the other tho. More to update later when problem is finally solved completely.
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    Replaced o2 sensors code popped right back on shortly after tho.
  16. #14
    san2cci's Avatar
    Dec 2011
    Camden County, NJ
    28
    410
    Which sensors did you replace? and whered you get your sensors?
  17. #15
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    Bosch oe fit downstreams
  18. Remove Advertisements
