I tried replacing my sway bar bushing... Pics
Results 1 to 9 of 9
Like Tree4Likes
  • 2 Post By RippyPartsDept
  • 6 Post By AAIIIC
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, I tried replacing my sway bar bushing... Pics in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Heres the sway bar bushing Here it is with the bracket off, notice how worn and flexible it is... completely ...
    rgvcts's Avatar
    rgvcts is offline Cadillac Owners Fanatic
    Automobile(s): 2005 3.6 CTS Luxury Sport
    Mar 2011
    McAllen, TX
    147
    completely off bracket and all Nut size 15mm...
    And this is the 23mm Energy Suspension replacement kit I got from Autozone... It was to small to fit so i returned it and my search for a replacement continues...
    I wonder if I ask Rippy, he can get me some new ones... anybody, any luck?
    josney's Avatar
    josney is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS
    Dec 2006
    South Carolina
    49
    2,296
    Re: I tried replacing my sway bar bushing... Pics
    i am sure rippy can get you new ones. i thought there was a thread floating around that a member had made a set work that he purchased and they were made of a red urethane. but i cant put my fingers on it, my computers seems to not want to work this early in the morning.
    edit, apparently my brain doesnt work this early either. the bushings i was thinking of was for the shifter linkage...sorry.
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    I've been on a search for poly bushings too. Can't find a listing anywhere for a CTS.
    Apparently the black poly ones are impregnated with graphite for lubrication.
    rgvcts's Avatar
    Mar 2011
    McAllen, TX
    147
    yep, mine are gone, flexible squishy worn out... , i'll get my VIN and send him a pm,
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    I just looked these up for a forum member this morning (he emailed me yesterday)
    PM or email me your VIN and i'll check yours
    SHORTSTACK and SHORTSTACK like this.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,216
    As the original poster already discovered, I posted a comment about making universal sway bar bushings work up front in this other thread. Then I saw this thread as I was searching for something at work and figured I'd come back and update it later.
    Quote Originally Posted by me
    You can use universal poly rear bushings - Energy Suspension and Prothane both make them (and there are probably other companies, too). The U-shaped bushing brackets come in a couple of different sizes, so you'll have to measure the bolt spacing of the stock bushing brackets to make sure you get the right size.
    Up front it's not as easy, because the front bushings have a weird J-shaped bracket (the rear side is ~2" longer than the front side). Hotchkis does away with that by including a spacer block and a longer bolt. This is the only semi-worthwhile picture I have of it:
    If you look to the right of the bushing, below the sway bar, you can see just the bottom portion of a black metal block - that's the spacer that Hotchkis includes. By putting that block in there, you can use a normal U-shaped bushing bracket (the silver bracket is Hotchkis' billet bracket - some folks have actually deformed the stock brackets). You could recreate the same effect with a stack of washers or maybe some pipe nipples cut to the proper length.
    On my car I'm using the the Hotchkis billet bushing bracket, Energy or Prothane (I can't remember which) 26mm bushings (for the stock 26.5mm V front bar) and the Hotchkis chunk of metal bracket spacer.
    RCVW, RCVW, rgvcts and 3 others like this.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    mragan01 is offline Cadillac Owners Member
    Automobile(s): 2006 CTS 3.6L
    Dec 2014
    3
    Is the sway bar busing supposed to fit tight around the sway bar. Mine looks like there is a gap at the top between the bar and bushing like the picture at the top of this thread.
    Thanks,
    Mike
    956Caddy's Avatar
    956Caddy is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac Cts Black Raven
    Apr 2012
    Harlingen,Tx
    289
    I got oem ones off ebay for $32 shipping included. If you want I can look at my purchase history to see the seller and pass info on to you. They were AcDelco oem
    AAIIIC's Avatar
    Aug 2007
    6,216
    Quote Originally Posted by mragan01 View Post
    The picture at the top of the thread is of an old, worn out bushing that the OP was replacing. If your bushings look like that, then they are also old and worn out.
  12. Remove Advertisements
