Results 1 to 14 of 14
Thread: Flex disc help
    Thyine is offline Cadillac Owners Member
    Automobile(s): 05 CTS
    Jun 2012
    Newport Beach, CA
    53
    Flex disc help
    Hi everyone I bought a used 05 (LY6, MV1)last month and was very happy with it, until one day after a few stop light sprints I notice a buzzing rattle from under the car and I think "great I broke my new toy" so I slide underneath to source the problem (cracked weld on exhaust shielding) and I noticed my front flex disc was shot... I think no problem I changed them on my old MB...Ha!... So after the abundance of info here on the forum I settle in on a pair of the CS couplers. I switch out the front one (back is in good shape) drop the car and go for a spin and instantly the car is vibrating and there is a shudder under certain loads. I made quite a bit of angle adjustments after which helped a lot.. passengers wont really notice the vibrations but I feel it in the wheel and shifter, there is still a slight shudder if you accelerate hard,but now its started squeaking.. sounds like the ujoint is bad I dont think its the center bearing, it chirps like a bird increasing with speed but not under all loads. Could I have slipped a spline without noticing? Car is smooth and silent coasting in neutral. I'm stumped, there were no issues before the swap. I just got the "clunk" when going into gear, Any one have any ideas before I bite the bullet and pick up a new drive shaft? Thanks in advance.
    bubba1228 is offline Cadillac Owners Member
    Automobile(s): 04 CTS
    Jan 2012
    34
    48
    Jun 2012
    Newport Beach, CA
    53
    Re: Flex disc help
    Thanks but I'm pretty sure buying anything from douchebag parts is a no no here on the forum... they
    even came up with a fake GM part # (they raised their prices too! Wtf C.S. is only $200 a pair) and like I said I already replaced it with the Creative Steel one so I'm not in need of the part.
  5. #4
    newy0rktrini's Avatar
    newy0rktrini is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Dec 2008
    Germany
    32
    159
    Re: Flex disc help
    I had the same issue. It turned out to be that the driveshaft wasn't seat right and after it was seated properly the bolts had to be tightened. I have the creative steel coupler for the front and back. It should be a simple fix.
  6. #5
    Sep 2007
    Wilmington, NC
    13,969
    Re: Flex disc help
    bubba's new around here... go easy on him
    as for your problem i really don't have any ideas ... it's one of those things that an expert has to look at, feel, touch, drive, etc
    good luck
  7. #6
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    Re: Flex disc help
    go with creative steel
    i know they fit because i took mine off, made a device mould out of it, locked it all up and shipped it back to him.
    i also checked the 03 3.2L against the 04 3.6L bushing. they are the same size, but slightly different design. they should be interchangeable .
  8. #7
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    Re: Flex disc help
    They look pretty sketchy in the picture.
  9. #8
    Jun 2012
    Newport Beach, CA
    53
    Re: Flex disc help
    Quote Originally Posted by newy0rktrini View Post
    Are you referring to the 3 pilots on each side? I put them in the yokes..I'll try loosening and re-torquing them
  10. #9
    Dec 2008
    Germany
    32
    159
    Re: Flex disc help
    I cheated a little because I did all the work then complained to my mechanic about the rattle and he said he would look at it. 5 minutes later, I was good. I think because I was restricted on space to put some power behind the lugs, it was loose enough to rattle
  11. #10
    Jan 2012
    34
    48
    Re: Flex disc help
    I bought a set of the revshift couplers and had the same issue squeeking creaking and vibration no matter how i shimmed them. I will stick with stock or as close to it as I can. Just my opinion though.
  12. #11
    Dec 2008
    Germany
    32
    159
    Re: Flex disc help
    I wouldn't knock them because I have them on my car and they work fine when installed properly. Just make sure your center bearing is still good. If that rubber bushing is torn that may be the problem as well. Good luck
  13. #12
    ciaracts is offline Cadillac Owners Member
    Automobile(s): CTS
    Mar 2012
    1
    Re: Flex disc help
    Hey Thyine -
    I have an '05 CTS 3.6 too. I replaced the front flex disk with a CS one and did the center bearing too. I am now experiencing the chirp on acceleration. Any ideas?
    Thanks -
    Scott
  14. #13
    Jun 2012
    Newport Beach, CA
    53
    Re: Flex disc help
    Is it smooth other then that? Did you do any shimming? I'm still not sure what it is, but its defiantly coming from the area of the flex disc that's as much as Ive been able to conclude so far, been really busy at work lately... anyways my latest hypothesis is that is could be angle induced perhaps my chasing down the vibrations and angle adjustments to compensate for a possibly bad center bearing has put stress on a bearing in the trans?. Anyone know if there's a bearing behind the trans flange? I emailed CS if they have come across anything like this and they think most likely its the center bearing that's the cause of the shuddering/vibration. I'm planning a few more tests as soon as I get a chance and will update.
  15. #14
    caddyshack33 is offline Cadillac Owners Fanatic
    Automobile(s): '04 CTS 3.2 5-spd Manual
    Oct 2007
    165
    I also had the CS flex disc installed, just on the front. Max (the owner) was very helpful with giving me some specs to ensure that the trans mount was shimmed properly. After trial and error, i got the angle "good enough" to reduce the buzzing on load vibration. These discs are not made of rubber and, unfortunately, transfer vibration more easily than the stock coupler. I had a feeling my driveshaft, replaced under warranty 40k miles ago, was not installed properly which is why the OEM flex disc got torn up. Too bad Cadillac didnt stand behind their work on that one -- but I wont go into my two-month battle with them over that. Im glad there are other options available.
  • You may not post replies
