Wheel Fitment
Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Like Tree1Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Wheel Fitment in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Ive searched and haven't seen a clear answer but will wheels with these specs fit correctly and not rub or ...
    itscody's Avatar
    itscody is offline Cadillac Owners Fanatic
    Automobile(s): CTS
    May 2012
    W.VA
    24
    120
    Wheel Fitment
    Ive searched and haven't seen a clear answer but will wheels with these specs fit correctly and not rub or require spacers, 20x8.5 -- 35offset 06 cts
    Fiero is offline Cadillac Owners Member
    Automobile(s): 2007 CTS 3.6L Performance / Appearance 18" rims
    Dec 2010
    Toronto, Ontario, Canada
    48
    Re: Wheel Fitment
    Good timing itscody!!
    I learned a lot by reading through several wheel fitment threads,
    BUT, I too was just about to ask the experts here for a quick "blessing" on the same thing before I pull the trigger on new shoes:
    245/35/20 on 20x8.5 +35 Offset on all four corners - 2007 CTS Performance / Appearance Package (FE5 with stock 18")
    1. Will the front rub the inner fender with 245 wide rubber?
    2. Will I be able to lower the car given these specs?
    3. Will I have to roll my fenders?
    4. Will I have to roll my fenders in order to lower the car with +35 offset and 245s?
    Any advise is much appreciated!
    FRANKIE FINGERS's Avatar
    FRANKIE FINGERS is offline Cadillac Owners Fanatic
    Automobile(s): CTS
    Feb 2012
    WHITTIER, SO CAL
    206
    Im running 245 x 35 x 20 with +38 offset and i dont rub at all on my 07.
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    Re: Wheel Fitment
    20x8.5 with a +35 offset on 245/35/20 tire will have a slight rub on the front tires and generally when you are turning right
    the perfect fitment is 20x8.5 on 245/35/20 tire with anything between a +38 to +42 offset
    the bolt pattern for the 1st gen CTS is 5 x 115...but 5 x 114.3 will fit but is recommended to use wobble lug nuts with them
    itscody's Avatar
    Automobile(s): CTS
    May 2012
    W.VA
    24
    120
    I pulled the trigger to soon then.
    I got 20x8.5 with a 35+ offset.
    And I refuse to use spacers.
    Is there a tire size that won't rub
    Automobile(s): CTS
    Feb 2012
    WHITTIER, SO CAL
    206
    Oh i forgot to mention my rim is a 20 x 9
    itscody's Avatar
    Automobile(s): CTS
    May 2012
    W.VA
    24
    120
    Maybe a 235/35/20 will eliminate the rubbing. Run those up front and 245/35/20 on the backs. ?
    itscody's Avatar
    Automobile(s): CTS
    May 2012
    W.VA
    24
    120
    Quote Originally Posted by FRANKIE FINGERS
    So if u figure the offset is 3 up. Mines 3 down. Ur rim is .5 wider mines .5 smaller. I should get away with 235 not rubbing.
    Automobile(s): CTS
    Feb 2012
    WHITTIER, SO CAL
    206
    Should work.
    itscody's Avatar
    Automobile(s): CTS
    May 2012
    W.VA
    24
    120
    I'll find out Monday
    Automobile(s): CTS
    Feb 2012
    WHITTIER, SO CAL
    206
    What are your rubbing on. If its just the inner plastic wheel wells. Just trim them
    txbest1980's Avatar
    Dec 2008
    36
    6,414
    Re: Wheel Fitment
    Quote Originally Posted by itscody View Post
    235 should not rub but it will be a bit of a rough ride compared to the 245
    Quote Originally Posted by FRANKIE FINGERS View Post
    your best bet with a 20 x 9 wheel is to roll your rear fenders and trim the inner wheel well plastic
    itscody's Avatar
    Automobile(s): CTS
    May 2012
    W.VA
    24
    120
    So is It the fender it rubs on or the control arm.
    Fenders I can deal with. I can fix that easily. So I'll go with 20x8.5 with a 245
  16. #14
    txbest1980's Avatar
    Dec 2008
    36
    6,414
    Re: Wheel Fitment
    you will rub on the inner fender lining with the 245
  17. #15
    itscody's Avatar
    Automobile(s): CTS
    May 2012
    W.VA
    24
    120
    Mine has been removed. So I should be ready to rocking n roll
  18. Remove Advertisements
