Wheel Fitment - Page 2
Results 16 to 30 of 42
Like Tree1Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Wheel Fitment in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Thanks for the insight on the 245 rubber and the wheel well rubbing. If I dropped to a more narrow ...
  1. #16
    Fiero is offline Cadillac Owners Member
    Automobile(s): 2007 CTS 3.6L Performance / Appearance 18" rims
    Dec 2010
    Toronto, Ontario, Canada
    48
    Re: Wheel Fitment
    If I dropped to a more narrow rim like 8 wide instead of 8.5 wide and kept the rubber at 245, would they still rub on the innner fenders on the front?
  2. #17
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    Re: Wheel Fitment
    with a 20 x 8 rim and the +35 offset, you should have little to no rubbing...it would more less depend on the actual brand of tire that would matter if you had slight rubbing issues, but you should be fine either way
  3. #18
    itscody's Avatar
    itscody is offline Cadillac Owners Fanatic
    Automobile(s): CTS
    May 2012
    W.VA
    24
    120
    Found out today with a 20x8.5 rim with 35+ offset. You need 225/35/30 tires. To avoid rubbing.
  5. #19
    itscody's Avatar
    Automobile(s): CTS
    May 2012
    W.VA
    24
    120
    After looking. My stock wheels are 225. So shouldn't be much of a difference.
  6. #20
    txbest1980's Avatar
    Dec 2008
    36
    6,414
    Re: Wheel Fitment
    Quote Originally Posted by itscody View Post
    your post dont add up to me. if you already have your inner fender liner out, then a 245 tire shouldnt rub...but now you say the above, which makes absolutely no sense. i have run a 20 x 9 with a 245 tire and took out my inner fender liners and didnt rub
    what size tire and rim size are you running? what brand tires as well?
  7. #21
    itscody's Avatar
    Automobile(s): CTS
    May 2012
    W.VA
    24
    120
    The wheels are 20x8.5. With a 35+ offset. I was told a 245/45/20 tire would rub on the control arm I guess it is. And that I would need a 225/35/20 tire to avoid rubbing ?
  8. #22
    itscody's Avatar
    Automobile(s): CTS
    May 2012
    W.VA
    24
    120
    245/35/20***
  9. #23
    txbest1980's Avatar
    Dec 2008
    36
    6,414
    Re: Wheel Fitment
    who is telling you this stuff? is it a wheel and tire shop?
  10. #24
    itscody's Avatar
    Automobile(s): CTS
    May 2012
    W.VA
    24
    120
    Quote Originally Posted by txbest1980
    The wheel shop I ordered wheels from said to avoid running use a 225/35/20
    But if I can use a different size tire. I wudent complain. But I didn't wanna buy tires and mount them. Cause then I won't be able to return the wheels.
  11. #25
    shthappens is offline Cadillac Owners Member
    Feb 2011
    3
    Re: Wheel Fitment
    Quote Originally Posted by Fiero View Post
    2007 CTS Performance / Appearance Package (FE5 with stock 18")
    First things first... sorry that I'm a long time lurker with no posts... but I do have some things to contribute! Along with the all important pictures =p
    Now Fiero, down to business, what's happening with those 18" wheels that you're replacing? I just had to ask seeing as you're only one city over, and as I'm in need of some new wheels
  12. #26
    Dec 2010
    48
    Re: Wheel Fitment
    itscody,
    I would more readily trust the guys and gals of this forum since they probably have more experience with the 1st gen CTS specifically.
    some wheel shops are at the top of thier game, while others may not have seen a 1st Gen CTS for over 5 years.
    Sounds to me like the shop you spoke to might be playing it safe by recommending the 225 wide, just so they dont get into unchartered territory - ie they dont want to take the risk becuase they've never worked on a CTS before.
    I've had one or two wheel and tire shops actually tell me that I cant put a 20" rims on my CTS- LOLOL!
    So get a couple of opinions to be sure...
    just my 2 cents.
  13. #27
    Dec 2010
    48
    Re: Wheel Fitment
    Quote Originally Posted by shthappens View Post
    Way to spot an opportunity!
    Unfortunately, I plan on keeping my stock rims for my Bridgestone Blizzak's, sorry bro!
    P.S. I'm actually in Mississauga - but now I gotta watch my car like a hawk in case you are lurking around the corner with a jackstand
    LOL, just messing around....
  14. #28
    itscody's Avatar
    Automobile(s): CTS
    May 2012
    W.VA
    24
    120
    Okay. So what do you guys recommend for 20x8.5 wheels with a 35+ offset. Keep in mind I refuse to use spacers.
  15. #29
    Dec 2010
    48
    Re: Wheel Fitment
    My plan is to go with the closest "diameter match" to my existing 18" stock setup so it doenst mess wiht my spedometer. (255/50/18)
    This means I will go with 245/35/20 (and hope to mount them on a 8" or 8.5" wide rim with +35 offsett).
    If there is rubbing on the inner liner then I will just trim the plastic wheel well liner.
    My only concern NOW is whether I can lower the car with my planned setup without any modifications, i.e. rolling the fenders.
    P.S. from what I've read, if you use spacers, that will only DECREASE your offset to about +20 which will not work for us (the less the + offsett the more the tire will stick out from the fenders). Also, in my readings, I didnt come across any solutions to INCREASE Offsett (i.e. to tuck the tires closer inside the fender - this what you and I really want).
    I wish the rims I have my heart set on had a +40 offset *sigh*
  16. #30
    itscody's Avatar
    Automobile(s): CTS
    May 2012
    W.VA
    24
    120
    <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=93349"/>
    My main concern is them rubbing on the upper control arm. I'm not worried about fenders really just the control arm. It looks like its really close. I'll take pic tomorrow to show you guys.
  17. Remove Advertisements
